> Key-in-ignition, Wired to the buzzer ?
jim_hoyland
post Nov 5 2015, 09:20 PM
Get that VIN ?
Was the ignition switch wired such that the warning buzzer would sound if the key was left in the ignition switch. The 911 ignition switches do for sure, how about a 914 ?
toolguy
post Nov 6 2015, 12:17 AM
Yes. . the 'buzzer' is what looks like a relay on the fuse tray under the dash. . except that this relay is red. . what makes the buzzing is the fact the relay is wired internally so it has a contact in the operate circuit so that as soon as it operated, the contact opens the path and the relay releases. . does this as fast as it can and causes a buzzing chatter.
If you don't like the buzzing, simply remove the relay. .
jim_hoyland   Key-in-ignition   Nov 5 2015, 09:20 PM
zambezi   Yes, mine does....'73.   Nov 5 2015, 10:05 PM
sb914   Was the ignition switch wired such that the warni...   Nov 5 2015, 10:07 PM
toolguy   Yes. . the 'buzzer' is what looks like a ...   Nov 6 2015, 12:17 AM
rgalla9146   Yes. . the 'buzzer' is what looks like a...   Nov 6 2015, 06:22 AM
jim_hoyland   OK; Now, what wire goes from the ignition switch t...   Nov 6 2015, 06:39 AM
CooltimesJr   got an ohm meter? i'm wondering if the two sma...   Nov 6 2015, 06:24 PM
jim_hoyland   got an ohm meter? i'm wondering if the two sm...   Nov 6 2015, 06:45 PM
jim_hoyland   I had a change to do some testing on a switch that...   Nov 8 2015, 06:42 PM
jim_hoyland   Still trying to figure this out….   Jun 24 2025, 08:26 PM
Superhawk996   Wiring is different early vs late. What year?   Jun 24 2025, 08:38 PM
jim_hoyland   Wiring is different early vs late. What year? ...   Jun 25 2025, 09:28 AM
JeffBowlsby   The buzzer on a 74-76 car is internal to the seatb...   Jun 24 2025, 08:42 PM
Superhawk996   The buzzer on a 74-76 car is internal to the seat...   Jun 24 2025, 08:51 PM
jim_hoyland   The buzzer on a 74-76 car is internal to the seat...   Jun 25 2025, 09:28 AM
JeffBowlsby   Thx for the update, I figgurd you may have been di...   Jun 24 2025, 09:11 PM
JeffBowlsby   Thx for the update, I figgurd you may have been di...   Jun 24 2025, 09:12 PM
Root_Werks   I used this wire to power the "on" for m...   Jun 25 2025, 09:39 AM
JeffBowlsby   Chassis harness schematic says its the grey/brown ...   Jun 25 2025, 10:42 AM
Root_Werks   Chassis harness schematic says its the grey/brown...   Jun 25 2025, 11:20 AM
Steve   Mine is also a 75. I bought a VW buzzer and was g...   Jun 25 2025, 10:49 AM
jim_hoyland   Does the grey/ brown go to the relay under the pas...   Jun 25 2025, 11:22 AM
JeffBowlsby   The 'buzzer' is internal to the seatbelt i...   Jun 25 2025, 12:11 PM
Superhawk996   Ok so here’s the thread going over how the later...   Jun 25 2025, 06:17 PM
jim_hoyland   Thanks for all that information :) Here’s what...   Jun 25 2025, 06:38 PM
Root_Werks   I believe the grey wire with brown stripe has 12v ...   Jun 25 2025, 07:34 PM
Root_Werks   BUT, if you're looking for a chime, this won...   Jun 25 2025, 07:36 PM
Superhawk996   BUT, if you're looking for a chime, this won...   Jun 25 2025, 07:44 PM
- Lo-Fi Version Time is now: 1st July 2025 - 06:02 AM
