jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,804 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Was the ignition switch wired such that the warning buzzer would sound if the key was left in the ignition switch. The 911 ignition switches do for sure, how about a 914 ?
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
Yes. . the 'buzzer' is what looks like a relay on the fuse tray under the dash. . except that this relay is red. . what makes the buzzing is the fact the relay is wired internally so it has a contact in the operate circuit so that as soon as it operated, the contact opens the path and the relay releases. . does this as fast as it can and causes a buzzing chatter.
If you don't like the buzzing, simply remove the relay. . |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,769 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Yes. . the 'buzzer' is what looks like a relay on the fuse tray under the dash. . except that this relay is red. . what makes the buzzing is the fact the relay is wired internally so it has a contact in the operate circuit so that as soon as it operated, the contact opens the path and the relay releases. . does this as fast as it can and causes a buzzing chatter. If you don't like the buzzing, simply remove the relay. . Isn't the buzzer a rectangular black one ? |
Lo-Fi Version | Time is now: 1st July 2025 - 07:09 AM |
