> Piston to Head Spec?
Jetsetsurfshop
post Nov 6 2015, 01:53 PM
I'm in the process of ordering some custom pistons and my Dad and I were thinking there must be a preferred distance from piston to head for the best combustion. Any thoughts?
(Its a 4, not a 6)
Thanks
Bills914-4
post Nov 6 2015, 02:18 PM
I'm running .032 , I've heard as little as .028 (Jake) , but I believe .035- .040 is
good (optimal) something to with quench, maybe some others will chime in , Bill D.
Jetsetsurfshop   Piston to Head Spec?   Nov 6 2015, 01:53 PM
WLD419   I'm running .032 , I've heard as little as...   Nov 6 2015, 02:18 PM
stugray   Do some googling of "deck height". It sh...   Nov 6 2015, 02:20 PM
r_towle   .040 is safe. deck height will set your compressi...   Nov 6 2015, 06:33 PM
Jetsetsurfshop   I googled it. Found some info here and on Pelican....   Nov 6 2015, 06:52 PM
WLD419   Are concern started because the PO shaved the h...   Nov 7 2015, 09:08 AM
sean_v8_914   head chamber volume in CCs? what is bore and strok...   Nov 6 2015, 06:55 PM
Jetsetsurfshop   head chamber volume in CCs? what is bore and stro...   Nov 6 2015, 06:58 PM
r_towle   You can order any pin height you require to get th...   Nov 6 2015, 07:34 PM
Racer Chris   That's a small combustion chamber for such a d...   Nov 7 2015, 06:11 AM
Bleyseng   What heads are those with a 49cc chamber?   Nov 7 2015, 08:08 AM
barefoot   What heads are those with a 49cc chamber? Good t...   Nov 13 2015, 05:46 AM
Montreal914   On my 2056 D-Jet build, I used .040" deck and...   Nov 7 2015, 09:08 AM
stugray   If they shaved the heads down to get the comb cham...   Nov 7 2015, 11:48 AM
Dave_Darling   For illustrations of how fly-cutting the heads can...   Nov 9 2015, 03:35 PM
Jetsetsurfshop   Ok, let me see if I can address everyone here. Fi...   Nov 9 2015, 04:03 PM
Jetsetsurfshop   Cant find a picture right now, I'll take one t...   Nov 9 2015, 04:05 PM
Jetsetsurfshop   :driving:   Nov 9 2015, 06:37 PM
r_towle   Ok, So what is the question again?   Nov 9 2015, 06:46 PM
Racer Chris   Find someone who can TIG weld that hole shut, grin...   Nov 10 2015, 09:48 AM
Jetsetsurfshop   Find someone who can TIG weld that hole shut, gri...   Nov 10 2015, 04:55 PM
stugray   I read precisely 60ccs on the 2.0L heads which was...   Nov 13 2015, 02:27 PM
barefoot   I read precisely 60ccs on the 2.0L heads which wa...   Nov 13 2015, 02:47 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:08 AM
