| Jetsetsurfshop |
Nov 6 2015, 01:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I'm in the process of ordering some custom pistons and my Dad and I were thinking there must be a preferred distance from piston to head for the best combustion. Any thoughts?
(Its a 4, not a 6) Thanks (IMG:style_emoticons/default/driving.gif) |
| Jetsetsurfshop |
Nov 6 2015, 06:52 PM
I googled it. Found some info here and on Pelican.
Are concern started because the PO shaved the heads. We are going to a bigger cam and need to add valve pockets. We didn't want to lose our compression in the process. Thinking we can get some back with little dome on the top. |
| Bills914-4 |
Nov 7 2015, 09:08 AM
Member ![]() ![]() Group: Members Posts: 313 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
Are concern started because the PO shaved the heads. We are going to a bigger cam and need to add valve pockets. My experience ,valve pockets only add 2cc-4cc max. , your cam choice is going to determine what C.R. you should setup , 10cc dish pistons would give you 9.5cr , valve pockets & a little chamber work, might get you 10.2 maybe 10.0cr , tighter deck = snappier throttle response (IMG:style_emoticons/default/smile.gif) , CB calculator http://www.cbperformance.com/v/enginecalc.html |
Jetsetsurfshop Piston to Head Spec? Nov 6 2015, 01:53 PM
WLD419 I'm running .032 , I've heard as little as... Nov 6 2015, 02:18 PM
stugray Do some googling of "deck height".
It sh... Nov 6 2015, 02:20 PM
r_towle .040 is safe.
deck height will set your compressi... Nov 6 2015, 06:33 PM
sean_v8_914 head chamber volume in CCs?
what is bore and strok... Nov 6 2015, 06:55 PM
Jetsetsurfshop
what is bore and stro... Nov 6 2015, 06:58 PM
r_towle You can order any pin height you require to get th... Nov 6 2015, 07:34 PM
Racer Chris That's a small combustion chamber for such a d... Nov 7 2015, 06:11 AM
Bleyseng What heads are those with a 49cc chamber? Nov 7 2015, 08:08 AM
barefoot
Good t... Nov 13 2015, 05:46 AM
Montreal914 On my 2056 D-Jet build, I used .040" deck and... Nov 7 2015, 09:08 AM
stugray If they shaved the heads down to get the comb cham... Nov 7 2015, 11:48 AM
Dave_Darling For illustrations of how fly-cutting the heads can... Nov 9 2015, 03:35 PM
Jetsetsurfshop Ok, let me see if I can address everyone here.
Fi... Nov 9 2015, 04:03 PM
Jetsetsurfshop Cant find a picture right now, I'll take one t... Nov 9 2015, 04:05 PM
Jetsetsurfshop :driving: Nov 9 2015, 06:37 PM
r_towle Ok,
So what is the question again? Nov 9 2015, 06:46 PM
Racer Chris Find someone who can TIG weld that hole shut, grin... Nov 10 2015, 09:48 AM
Jetsetsurfshop
Find someone who can TIG weld that hole shut, gri... Nov 10 2015, 04:55 PM
stugray I read precisely 60ccs on the 2.0L heads which was... Nov 13 2015, 02:27 PM
barefoot
I read precisely 60ccs on the 2.0L heads which wa... Nov 13 2015, 02:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:09 AM |
