| Jetsetsurfshop |
Nov 6 2015, 01:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I'm in the process of ordering some custom pistons and my Dad and I were thinking there must be a preferred distance from piston to head for the best combustion. Any thoughts?
(Its a 4, not a 6) Thanks (IMG:style_emoticons/default/driving.gif) |
| stugray |
Nov 7 2015, 11:48 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
If they shaved the heads down to get the comb chambers to 49 ccs, they may have shaved them too far.
I tried to do the very same thing, but the Porsche mechanic/machinst advised against it. He said that machining the heads that far will make the metal too thin where the exhaust studs thread in risking blowing them out. So he shaved them down for me but only to the point where I had 54 ccs comb chamber volume. The deck height requirement of > ~0.028 (call it .030 for some margin) is to keep the piston tops from hitting the flat portion of the head when the pistons reach max temp. I have .035 and ~.5 valve lift (webcam 86b) and have plenty of clearance from the valves hitting the piston (stock valves). Once you get everything dialed in, do the clay method of checking valve clearance. Put a lump of clay on the piston , reassemble, and crank once around. Then disassemble and measure the indentations in the clay. http://www.914world.com/bbs2/index.php?showtopic=200247 |
Jetsetsurfshop Piston to Head Spec? Nov 6 2015, 01:53 PM
WLD419 I'm running .032 , I've heard as little as... Nov 6 2015, 02:18 PM
stugray Do some googling of "deck height".
It sh... Nov 6 2015, 02:20 PM
r_towle .040 is safe.
deck height will set your compressi... Nov 6 2015, 06:33 PM
Jetsetsurfshop I googled it. Found some info here and on Pelican.... Nov 6 2015, 06:52 PM
WLD419
Are concern started because the PO shaved the h... Nov 7 2015, 09:08 AM
sean_v8_914 head chamber volume in CCs?
what is bore and strok... Nov 6 2015, 06:55 PM
Jetsetsurfshop
what is bore and stro... Nov 6 2015, 06:58 PM
r_towle You can order any pin height you require to get th... Nov 6 2015, 07:34 PM
Racer Chris That's a small combustion chamber for such a d... Nov 7 2015, 06:11 AM
Bleyseng What heads are those with a 49cc chamber? Nov 7 2015, 08:08 AM
barefoot
Good t... Nov 13 2015, 05:46 AM
Montreal914 On my 2056 D-Jet build, I used .040" deck and... Nov 7 2015, 09:08 AM
Dave_Darling For illustrations of how fly-cutting the heads can... Nov 9 2015, 03:35 PM
Jetsetsurfshop Ok, let me see if I can address everyone here.
Fi... Nov 9 2015, 04:03 PM
Jetsetsurfshop Cant find a picture right now, I'll take one t... Nov 9 2015, 04:05 PM
Jetsetsurfshop :driving: Nov 9 2015, 06:37 PM
r_towle Ok,
So what is the question again? Nov 9 2015, 06:46 PM
Racer Chris Find someone who can TIG weld that hole shut, grin... Nov 10 2015, 09:48 AM
Jetsetsurfshop
Find someone who can TIG weld that hole shut, gri... Nov 10 2015, 04:55 PM
stugray I read precisely 60ccs on the 2.0L heads which was... Nov 13 2015, 02:27 PM
barefoot
I read precisely 60ccs on the 2.0L heads which wa... Nov 13 2015, 02:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:05 AM |
