| Jetsetsurfshop |
Nov 6 2015, 01:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I'm in the process of ordering some custom pistons and my Dad and I were thinking there must be a preferred distance from piston to head for the best combustion. Any thoughts?
(Its a 4, not a 6) Thanks (IMG:style_emoticons/default/driving.gif) |
| Jetsetsurfshop |
Nov 9 2015, 04:03 PM
Ok, let me see if I can address everyone here.
First off, its for a track car and we only run 98 octane fuel. So the having a compression of 10 to 1 wasn't a issue. It was what we wanted. I think I said it wasn't me that flycut the heads it was the PO. Pin hight is already into the oil ring already and I want the compression ratio high. I dont know who did the heads but they have monster valves and there's R.J. initialed on them. last thing to address is that i will never cut your heads down this low. What Sturay and Dave said is correct. Check out the picture. The hole was there when we rebuilt it last year. We stuck some JB weld over the hole and ran it in dozens of HPDE's and one 14 hour Chump Car race. When we pulled the head the JB weld was gone and the exhaust stud worked its way out a little bit. We could of just pulled the head and did a quick repair but as a race engine we wanted to see the bearing and camshaft wear. (the web cam was pretty beat, fyi) The plan is to run it for another year and order up some new heads then. Need to save a few bucks for those! |
Jetsetsurfshop Piston to Head Spec? Nov 6 2015, 01:53 PM
WLD419 I'm running .032 , I've heard as little as... Nov 6 2015, 02:18 PM
stugray Do some googling of "deck height".
It sh... Nov 6 2015, 02:20 PM
r_towle .040 is safe.
deck height will set your compressi... Nov 6 2015, 06:33 PM
Jetsetsurfshop I googled it. Found some info here and on Pelican.... Nov 6 2015, 06:52 PM
WLD419
Are concern started because the PO shaved the h... Nov 7 2015, 09:08 AM
sean_v8_914 head chamber volume in CCs?
what is bore and strok... Nov 6 2015, 06:55 PM
Jetsetsurfshop
what is bore and stro... Nov 6 2015, 06:58 PM
r_towle You can order any pin height you require to get th... Nov 6 2015, 07:34 PM
Racer Chris That's a small combustion chamber for such a d... Nov 7 2015, 06:11 AM
Bleyseng What heads are those with a 49cc chamber? Nov 7 2015, 08:08 AM
barefoot
Good t... Nov 13 2015, 05:46 AM
Montreal914 On my 2056 D-Jet build, I used .040" deck and... Nov 7 2015, 09:08 AM
stugray If they shaved the heads down to get the comb cham... Nov 7 2015, 11:48 AM
Dave_Darling For illustrations of how fly-cutting the heads can... Nov 9 2015, 03:35 PM
Jetsetsurfshop Cant find a picture right now, I'll take one t... Nov 9 2015, 04:05 PM
Jetsetsurfshop :driving: Nov 9 2015, 06:37 PM
r_towle Ok,
So what is the question again? Nov 9 2015, 06:46 PM
Racer Chris Find someone who can TIG weld that hole shut, grin... Nov 10 2015, 09:48 AM
Jetsetsurfshop
Find someone who can TIG weld that hole shut, gri... Nov 10 2015, 04:55 PM
stugray I read precisely 60ccs on the 2.0L heads which was... Nov 13 2015, 02:27 PM
barefoot
I read precisely 60ccs on the 2.0L heads which wa... Nov 13 2015, 02:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:36 AM |
