Fire Extinguisher recommendations |
Cal |
Nov 21 2015, 05:48 PM
Senior Member Group: Members Posts: 615 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
I'm looking for recommendations for the best compact fire extinguisher for a 914 as well as possible mounting locations.
GeorgeRud |
Nov 22 2015, 09:19 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Mounting one to a piece of angle iron mounted transversely in front of the passenger seat seems the easiest. By making short extensions on the ends, you can simply bolt the mount to the front seat mounting bolts so it moves with the seat if your seat is the later style. The vertical portion of the angle iron provides a great surface to attach the extinguisher mount.
I'd chose a Halon or foam extinguisher. The foam types help prevent re-ignition after putting out a fire. |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:08 AM |
