| Cracker |
Nov 24 2015, 08:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States
The first video shows a couple laps running behind the 914/6/3.0 (SixAddict) of a good friend. The longer part shows a little more solo action...man these cars are fun!
Second Day after changes (1 lap only) - amazing balance in the car! https://youtu.be/NhHMaa0_R5o https://www.youtube.com/watch?v=NhHMaa0_R5o https://youtu.be/LfFdP8GnXiQ (12+ minutes) https://www.youtube.com/watch?v=LfFdP8GnXiQ https://youtu.be/9Te6GScwxek (3 minutes) https://www.youtube.com/watch?v=9Te6GScwxek The GT3 Cup is faster everywhere but still allot of fun to (try) keep up with. I might be a smidgen faster down the straights - barely at best. Tony |
| Dave_Darling |
Nov 24 2015, 11:13 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
How confident are you in your suspension pick-up points? In the suspension members themselves? Could anything be flexing overly?
--DD |
| stownsen914 |
Nov 25 2015, 05:52 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 996 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I didn't see what tires you are running. Camber settings are very different for different tires (e.g. radials - slicks or DOT style - like more camber than bias ply tires). With that said, your settings seem in the ballpark, though you might want more camber for R compound radials.
What struck me is your toe settings. For a track car, I like toe out in front - about 1/16" total toe out. In the rear, for a 914 you need 1/4" total toe in as mentioned in the earlier post. As for the dartiness you mention. you have 0 toe in the back. The rear is probably toeing out while you are driving, due to flex (and also the 914 rear suspension naturally toes out under compression). Rear toe-out will definitely make the car feel darty. You can also check for any looseness in your suspension, and make sure your rear suspension mounting point in particular are solid, since that is a weak area in 914s. Scott |
Cracker 914/LS vs 914/6 Nov 24 2015, 08:42 PM
ThePaintedMan A lot of guys will run 1/16-1/8th toe in on the re... Nov 24 2015, 08:49 PM
wndsrfr I'm not an expert but am thinking it's not... Nov 24 2015, 09:01 PM
Cracker John - I did fail to mention that the front and re... Nov 24 2015, 09:06 PM
JamesM
John - I did fail to mention that the front and r... Nov 25 2015, 11:34 AM
Andyrew
John - I did fail to mention that the front and r... Nov 25 2015, 11:41 AM
r_towle My opinion only.
Your tub has some fixed limits.
... Nov 24 2015, 10:13 PM
Cracker Scott, Rich & Dave - Thanks to you all. I did ... Nov 25 2015, 06:37 AM
stownsen914
From what I've gathered, do you'all agree... Nov 25 2015, 07:37 AM
r_towle
Scott, Rich & Dave - Thanks to you all. I did... Nov 25 2015, 08:38 AM
stugray
In the front, again, the tub will dictate what yo... Nov 26 2015, 11:37 AM
ThePaintedMan Tony, good tips from Rich and the other folks here... Nov 25 2015, 09:01 AM
andys IMHO, There are street settings, and there are tra... Nov 25 2015, 10:50 AM
Cracker Andys - I agree. Yes, I do have a tire temp probe ... Nov 25 2015, 05:50 PM
r_towle You have some unique setup requirements for that c... Nov 25 2015, 07:19 PM
andys Tony,
Careful with the aero balance at those kind... Nov 25 2015, 07:43 PM
Cracker Andys: Guard LSD 40/60
[quote name='andys' pos... Nov 25 2015, 08:52 PM
r_towle I think the rear wing is too small.... Nov 25 2015, 09:13 PM
messix whats the caster at? Nov 25 2015, 09:15 PM
Cracker
We don't know where c... Nov 26 2015, 07:23 AM
brant Stu. Check in with me at some point. There are a ... Nov 26 2015, 12:29 PM
messix find what the caster is set at. i bet its pretty l... Nov 26 2015, 03:30 PM
Cracker
find what the caster is set at. i bet its pretty ... Nov 26 2015, 03:47 PM
r_towle
find what the caster is set at. i bet its pretty... Nov 26 2015, 06:06 PM
Cracker LOL. It felt better today WITH the blown shock. I ... Nov 26 2015, 06:14 PM
Dave_Darling Thanks for the tip. Please define, in your words ... Nov 26 2015, 08:46 PM
Cracker Thank you Dave...I know what that is but was curio... Nov 26 2015, 09:12 PM
r_towle The wing is too small....that will fix it. Nov 26 2015, 06:18 PM
Cracker You do have a thing with my wing... :shades2:
T... Nov 26 2015, 06:38 PM
mgp4591 Think of negative caster as what the grocery cart ... Nov 26 2015, 11:52 PM
messix a low number would be 0 to +3, higher number would... Nov 27 2015, 12:37 AM
messix cliff notes or front set up for dummies http://www... Nov 27 2015, 12:39 AM
Cracker Thanks fella's. I understood "caster... Nov 27 2015, 07:08 AM
messix
Thanks fella's. I understood "caster... Nov 27 2015, 10:38 PM
Cracker I certainly didn't mean to hurt feelings...tha... Nov 28 2015, 06:47 AM
Dave_Darling I don't think you can set a 914 up with negati... Nov 27 2015, 10:38 AM
r_towle Push the top of the strut back towards the windshi... Nov 27 2015, 10:48 AM
Cracker Yes'm... ;-)
T Nov 27 2015, 05:12 PM
r_towle Cracker, rear this
http://www.cassidy-online.com/... Nov 27 2015, 08:18 PM
Cracker Thanks. I remember seeing that years ago...very in... Nov 27 2015, 08:47 PM
jimkelly do I have this right for front? Nov 28 2015, 07:03 AM
Cracker Just don't max out your "toe-in" (ad... Nov 28 2015, 07:08 AM
r_towle
Yes, you have it... Nov 28 2015, 09:59 AM
stugray Since this racing front suspension oriented thread... Nov 28 2015, 02:23 PM
Dave_Darling Lengthening the A-arms is somewhat common in the 9... Nov 28 2015, 06:39 PM
Cracker Dave - I've thought about doing that conversio... Nov 28 2015, 06:59 PM
Cracker UPDATE: So thanks to everyone for your input...I a... Dec 4 2015, 11:05 AM
andys Tony,
Looks like you're all set to go. When y... Dec 4 2015, 12:37 PM
Cracker Sorry Andy for the late reply...just got to the ho... Dec 4 2015, 10:38 PM
Cracker UPDATE:
Okay. I had a good day. Still running aft... Dec 5 2015, 09:14 PM
wndsrfr
UPDATE:
Okay. I had a good day. Still running af... Dec 6 2015, 03:02 PM
andys Tony,
Looks like a fun drive! Anything to rep... Dec 6 2015, 11:32 AM
Andyrew Awesome! Looks like the chassis is really stab... Dec 6 2015, 12:10 PM
Cracker My good buddy, Terry O'Toole (SixAddict)... Dec 6 2015, 08:07 PM
Justinp71 Nice Car! Awesome video chasing the GT3 Dec 7 2015, 07:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:18 AM |
