> 914/LS vs 914/6
Cracker
post Nov 24 2015, 08:42 PM
The first video shows a couple laps running behind the 914/6/3.0 (SixAddict) of a good friend. The longer part shows a little more solo action...man these cars are fun!
Second Day after changes (1 lap only) - amazing balance in the car!
https://youtu.be/NhHMaa0_R5o
https://www.youtube.com/watch?v=NhHMaa0_R5o
https://youtu.be/LfFdP8GnXiQ (12+ minutes)
https://www.youtube.com/watch?v=LfFdP8GnXiQ
https://youtu.be/9Te6GScwxek (3 minutes)
https://www.youtube.com/watch?v=9Te6GScwxek
The GT3 Cup is faster everywhere but still allot of fun to (try) keep up with. I might be a smidgen faster down the straights - barely at best.
Tony
Cracker
post Nov 25 2015, 06:37 AM
Scott, Rich & Dave - Thanks to you all. I did "search" the paddock for info but didn't find anything "right on" with what I was experiencing.
The entire rear suspension has been reinforced (Chris Foley's) along with Patrick M. arms. All the bushings are poly (noisy!) and new. Very tight.
I added the "tire" and "springs" in my second post - Hoosier R7 but I'm sorting on the street right now with 5-year old Victoracers. It sounds like the the culprit might be the rear toe since I'm experiencing the WORST while under heavier acceleration. If I'm going down the highway
at 75, at static speed, its not nearly as bad.
From what I've gathered, do you'all agree with having 1/4 MORE camber in the rear's than the fronts? If so, I'm well short currently in the rear...how will increasing my rear camber .75 degrees affect toe out (under acceleration)? More sensitive or less?
Thanks!
Tony
Cracker   914/LS vs 914/6   Nov 24 2015, 08:42 PM
ThePaintedMan   A lot of guys will run 1/16-1/8th toe in on the re...   Nov 24 2015, 08:49 PM
wndsrfr   I'm not an expert but am thinking it's not...   Nov 24 2015, 09:01 PM
Cracker   John - I did fail to mention that the front and re...   Nov 24 2015, 09:06 PM
JamesM   John - I did fail to mention that the front and r...   Nov 25 2015, 11:34 AM
Andyrew   John - I did fail to mention that the front and r...   Nov 25 2015, 11:41 AM
r_towle   My opinion only. Your tub has some fixed limits. ...   Nov 24 2015, 10:13 PM
Dave_Darling   How confident are you in your suspension pick-up p...   Nov 24 2015, 11:13 PM
stownsen914   I didn't see what tires you are running. Cambe...   Nov 25 2015, 05:52 AM
Cracker   Scott, Rich & Dave - Thanks to you all. I did ...   Nov 25 2015, 06:37 AM
stownsen914   From what I've gathered, do you'all agree...   Nov 25 2015, 07:37 AM
r_towle   Scott, Rich & Dave - Thanks to you all. I did...   Nov 25 2015, 08:38 AM
stugray   In the front, again, the tub will dictate what yo...   Nov 26 2015, 11:37 AM
ThePaintedMan   Tony, good tips from Rich and the other folks here...   Nov 25 2015, 09:01 AM
andys   IMHO, There are street settings, and there are tra...   Nov 25 2015, 10:50 AM
Cracker   Andys - I agree. Yes, I do have a tire temp probe ...   Nov 25 2015, 05:50 PM
r_towle   You have some unique setup requirements for that c...   Nov 25 2015, 07:19 PM
andys   Tony, Careful with the aero balance at those kind...   Nov 25 2015, 07:43 PM
Cracker   Andys: Guard LSD 40/60 [quote name='andys' pos...   Nov 25 2015, 08:52 PM
r_towle   I think the rear wing is too small....   Nov 25 2015, 09:13 PM
messix   whats the caster at?   Nov 25 2015, 09:15 PM
Cracker   whats the caster at? We don't know where c...   Nov 26 2015, 07:23 AM
brant   Stu. Check in with me at some point. There are a ...   Nov 26 2015, 12:29 PM
messix   find what the caster is set at. i bet its pretty l...   Nov 26 2015, 03:30 PM
Cracker   find what the caster is set at. i bet its pretty ...   Nov 26 2015, 03:47 PM
r_towle   find what the caster is set at. i bet its pretty...   Nov 26 2015, 06:06 PM
Cracker   LOL. It felt better today WITH the blown shock. I ...   Nov 26 2015, 06:14 PM
Dave_Darling   Thanks for the tip. Please define, in your words ...   Nov 26 2015, 08:46 PM
Cracker   Thank you Dave...I know what that is but was curio...   Nov 26 2015, 09:12 PM
r_towle   The wing is too small....that will fix it.   Nov 26 2015, 06:18 PM
Cracker   You do have a thing with my wing... :shades2: T...   Nov 26 2015, 06:38 PM
mgp4591   Think of negative caster as what the grocery cart ...   Nov 26 2015, 11:52 PM
messix   a low number would be 0 to +3, higher number would...   Nov 27 2015, 12:37 AM
messix   cliff notes or front set up for dummies http://www...   Nov 27 2015, 12:39 AM
Cracker   Thanks fella's. I understood "caster...   Nov 27 2015, 07:08 AM
messix   Thanks fella's. I understood "caster...   Nov 27 2015, 10:38 PM
Cracker   I certainly didn't mean to hurt feelings...tha...   Nov 28 2015, 06:47 AM
Dave_Darling   I don't think you can set a 914 up with negati...   Nov 27 2015, 10:38 AM
r_towle   Push the top of the strut back towards the windshi...   Nov 27 2015, 10:48 AM
Cracker   Yes'm... ;-) T   Nov 27 2015, 05:12 PM
r_towle   Cracker, rear this http://www.cassidy-online.com/...   Nov 27 2015, 08:18 PM
Cracker   Thanks. I remember seeing that years ago...very in...   Nov 27 2015, 08:47 PM
jimkelly   do I have this right for front?   Nov 28 2015, 07:03 AM
Cracker   Just don't max out your "toe-in" (ad...   Nov 28 2015, 07:08 AM
r_towle   do I have this right for front? Yes, you have it...   Nov 28 2015, 09:59 AM
stugray   Since this racing front suspension oriented thread...   Nov 28 2015, 02:23 PM
Dave_Darling   Lengthening the A-arms is somewhat common in the 9...   Nov 28 2015, 06:39 PM
Cracker   Dave - I've thought about doing that conversio...   Nov 28 2015, 06:59 PM
Cracker   UPDATE: So thanks to everyone for your input...I a...   Dec 4 2015, 11:05 AM
andys   Tony, Looks like you're all set to go. When y...   Dec 4 2015, 12:37 PM
Cracker   Sorry Andy for the late reply...just got to the ho...   Dec 4 2015, 10:38 PM
Cracker   UPDATE: Okay. I had a good day. Still running aft...   Dec 5 2015, 09:14 PM
wndsrfr   UPDATE: Okay. I had a good day. Still running af...   Dec 6 2015, 03:02 PM
andys   Tony, Looks like a fun drive! Anything to rep...   Dec 6 2015, 11:32 AM
Andyrew   Awesome! Looks like the chassis is really stab...   Dec 6 2015, 12:10 PM
Cracker   My good buddy, Terry O'Toole (SixAddict)...   Dec 6 2015, 08:07 PM
Justinp71   Nice Car! Awesome video chasing the GT3   Dec 7 2015, 07:02 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:47 AM
