| Cracker |
Nov 24 2015, 08:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States
The first video shows a couple laps running behind the 914/6/3.0 (SixAddict) of a good friend. The longer part shows a little more solo action...man these cars are fun!
Second Day after changes (1 lap only) - amazing balance in the car! https://youtu.be/NhHMaa0_R5o https://www.youtube.com/watch?v=NhHMaa0_R5o https://youtu.be/LfFdP8GnXiQ (12+ minutes) https://www.youtube.com/watch?v=LfFdP8GnXiQ https://youtu.be/9Te6GScwxek (3 minutes) https://www.youtube.com/watch?v=9Te6GScwxek The GT3 Cup is faster everywhere but still allot of fun to (try) keep up with. I might be a smidgen faster down the straights - barely at best. Tony |
| Cracker |
Nov 25 2015, 06:37 AM
Scott, Rich & Dave - Thanks to you all. I did "search" the paddock for info but didn't find anything "right on" with what I was experiencing.
The entire rear suspension has been reinforced (Chris Foley's) along with Patrick M. arms. All the bushings are poly (noisy!) and new. Very tight. I added the "tire" and "springs" in my second post - Hoosier R7 but I'm sorting on the street right now with 5-year old Victoracers. It sounds like the the culprit might be the rear toe since I'm experiencing the WORST while under heavier acceleration. If I'm going down the highway at 75, at static speed, its not nearly as bad. From what I've gathered, do you'all agree with having 1/4 MORE camber in the rear's than the fronts? If so, I'm well short currently in the rear...how will increasing my rear camber .75 degrees affect toe out (under acceleration)? More sensitive or less? Thanks! Tony |
| stownsen914 |
Nov 25 2015, 07:37 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 996 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
From what I've gathered, do you'all agree with having 1/4 MORE camber in the rear's than the fronts? If so, I'm well short currently in the rear...how will increasing my rear camber .75 degrees affect toe out (under acceleration)? More sensitive or less? Personally I run less camber in the rear since my rear tires are wider. This is a pretty typical setup from what I understand. What tires are you running? Definitely fix the rear toe though. And for the front you could probably go with 0 toe rather than toe out if you're driving on the street. |
Cracker 914/LS vs 914/6 Nov 24 2015, 08:42 PM
ThePaintedMan A lot of guys will run 1/16-1/8th toe in on the re... Nov 24 2015, 08:49 PM
wndsrfr I'm not an expert but am thinking it's not... Nov 24 2015, 09:01 PM
Cracker John - I did fail to mention that the front and re... Nov 24 2015, 09:06 PM
JamesM
John - I did fail to mention that the front and r... Nov 25 2015, 11:34 AM
Andyrew
John - I did fail to mention that the front and r... Nov 25 2015, 11:41 AM
r_towle My opinion only.
Your tub has some fixed limits.
... Nov 24 2015, 10:13 PM
Dave_Darling How confident are you in your suspension pick-up p... Nov 24 2015, 11:13 PM
stownsen914 I didn't see what tires you are running. Cambe... Nov 25 2015, 05:52 AM
r_towle
Scott, Rich & Dave - Thanks to you all. I did... Nov 25 2015, 08:38 AM
stugray
In the front, again, the tub will dictate what yo... Nov 26 2015, 11:37 AM
ThePaintedMan Tony, good tips from Rich and the other folks here... Nov 25 2015, 09:01 AM
andys IMHO, There are street settings, and there are tra... Nov 25 2015, 10:50 AM
Cracker Andys - I agree. Yes, I do have a tire temp probe ... Nov 25 2015, 05:50 PM
r_towle You have some unique setup requirements for that c... Nov 25 2015, 07:19 PM
andys Tony,
Careful with the aero balance at those kind... Nov 25 2015, 07:43 PM
Cracker Andys: Guard LSD 40/60
[quote name='andys' pos... Nov 25 2015, 08:52 PM
r_towle I think the rear wing is too small.... Nov 25 2015, 09:13 PM
messix whats the caster at? Nov 25 2015, 09:15 PM
Cracker
We don't know where c... Nov 26 2015, 07:23 AM
brant Stu. Check in with me at some point. There are a ... Nov 26 2015, 12:29 PM
messix find what the caster is set at. i bet its pretty l... Nov 26 2015, 03:30 PM
Cracker
find what the caster is set at. i bet its pretty ... Nov 26 2015, 03:47 PM
r_towle
find what the caster is set at. i bet its pretty... Nov 26 2015, 06:06 PM
Cracker LOL. It felt better today WITH the blown shock. I ... Nov 26 2015, 06:14 PM
Dave_Darling Thanks for the tip. Please define, in your words ... Nov 26 2015, 08:46 PM
Cracker Thank you Dave...I know what that is but was curio... Nov 26 2015, 09:12 PM
r_towle The wing is too small....that will fix it. Nov 26 2015, 06:18 PM
Cracker You do have a thing with my wing... :shades2:
T... Nov 26 2015, 06:38 PM
mgp4591 Think of negative caster as what the grocery cart ... Nov 26 2015, 11:52 PM
messix a low number would be 0 to +3, higher number would... Nov 27 2015, 12:37 AM
messix cliff notes or front set up for dummies http://www... Nov 27 2015, 12:39 AM
Cracker Thanks fella's. I understood "caster... Nov 27 2015, 07:08 AM
messix
Thanks fella's. I understood "caster... Nov 27 2015, 10:38 PM
Cracker I certainly didn't mean to hurt feelings...tha... Nov 28 2015, 06:47 AM
Dave_Darling I don't think you can set a 914 up with negati... Nov 27 2015, 10:38 AM
r_towle Push the top of the strut back towards the windshi... Nov 27 2015, 10:48 AM
Cracker Yes'm... ;-)
T Nov 27 2015, 05:12 PM
r_towle Cracker, rear this
http://www.cassidy-online.com/... Nov 27 2015, 08:18 PM
Cracker Thanks. I remember seeing that years ago...very in... Nov 27 2015, 08:47 PM
jimkelly do I have this right for front? Nov 28 2015, 07:03 AM
Cracker Just don't max out your "toe-in" (ad... Nov 28 2015, 07:08 AM
r_towle
Yes, you have it... Nov 28 2015, 09:59 AM
stugray Since this racing front suspension oriented thread... Nov 28 2015, 02:23 PM
Dave_Darling Lengthening the A-arms is somewhat common in the 9... Nov 28 2015, 06:39 PM
Cracker Dave - I've thought about doing that conversio... Nov 28 2015, 06:59 PM
Cracker UPDATE: So thanks to everyone for your input...I a... Dec 4 2015, 11:05 AM
andys Tony,
Looks like you're all set to go. When y... Dec 4 2015, 12:37 PM
Cracker Sorry Andy for the late reply...just got to the ho... Dec 4 2015, 10:38 PM
Cracker UPDATE:
Okay. I had a good day. Still running aft... Dec 5 2015, 09:14 PM
wndsrfr
UPDATE:
Okay. I had a good day. Still running af... Dec 6 2015, 03:02 PM
andys Tony,
Looks like a fun drive! Anything to rep... Dec 6 2015, 11:32 AM
Andyrew Awesome! Looks like the chassis is really stab... Dec 6 2015, 12:10 PM
Cracker My good buddy, Terry O'Toole (SixAddict)... Dec 6 2015, 08:07 PM
Justinp71 Nice Car! Awesome video chasing the GT3 Dec 7 2015, 07:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:44 AM |
