Converting from Fuel Injection to Carbs, Need Fuel Distrabution help |
Robin914-4 |
Nov 28 2015, 12:06 PM
Newbie Group: Members Posts: 10 Joined: 28-November 15 From: Statesboro, Georgia Member No.: 19,419 Region Association: South East States |
Hey Everybody. I have been searching for an hour with no luck. I have a 1976 914/4 that I have converted over to 44mm Empi's. Now I am setting up the fuel system, new low pressure pump, stainless lines, presure regulator, etc. what I can't figure out is what to do with the extra line I have on the fuel tank. Should I cap it? Vent it? I did run both stainless line back to the engine bay so I could t them in or what ever. I just need some guidance.
Thanks in advance. Robin |
Dave_Darling |
Nov 28 2015, 06:20 PM
Looks like you don't have the thermostat flaps. YOU NEED THOSE FLAPS. Your engine will run way too hot without them.
--DD |
SirAndy |
Nov 28 2015, 06:39 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Looks like you don't have the thermostat flaps. YOU NEED THOSE FLAPS. Your engine will run way too hot without them. (IMG:style_emoticons/default/agree.gif) Also, using the return line is beneficial on a carbed engine. The constant fuel flow through the lines helps preventing the fuel from getting too hot. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 12:52 AM |
