Need a new transmission...so, what gear ratios?, 2.7L |
billh1963 |
Nov 28 2015, 05:40 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
My '72 with a 2.7 six is back.
The engine is running great. However, the gear box is so shitty it's not even worth driving. I've owned a lot of 914's and never had a gearbox so bad. I tried to go for a drive today and made it about 2 miles before I gave up and headed home. I felt like leaving it on the side of the road for the trash collector. Seriously,it's that shitty. The couple times I found second gear it wanted to crunch so I think I'm going to just rebuild it (of course all the shifter bushings and everything related to shifting will be gone through and updated). So, I've looked at several threads and even found some charts of gear ratios/rpm/speeds. For those with a 2.7 or 3.0, did you use the stock ratios? Are you happy with that? What would you change? I'm thinking of changing fifth gear to cruise around 2800-3000 rpm at 70mph. Will that give me enough fan speed to keep the oil cool? I do NOT have an external oil cooler. Tires size is 205/55-16 Any input is appreciated. Thank you |
Steve |
Nov 28 2015, 06:40 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I had a 2.7 with webers and headers and I was happy with the stock gears. I also drove a stock 3.0 with stock injection and also thought the stock gears were fine. It wasn't until I upgraded to the 3.2, that I thought the stock gears were all wrong. I have since upgraded the stock trans with a late 915 gear box to better match my 3.2 motor. Couldn't be happier, but the 915 gear box does not shift as easy as a 901.
billh1963 |
Nov 28 2015, 06:48 PM
I had a 2.7 with webers and headers and I was happy with the stock gears. I also drove a stock 3.0 with stock injection and also thought the stock gears were fine. It wasn't until I upgraded to the 3.2, that I thought the stock gears were all wrong. I have since upgraded the stock trans with a late 915 gear box to better match my 3.2 motor. Couldn't be happier, but the 915 gear box does not shift as easy as a 901. Thanks, Steve. I think the 901 will be fine for the hp of the 2.7. I think a 915 would be overkill for my needs. I do like the idea of dropping the RPM at highway speeds; albeit, not at the expense of oil cooling. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:26 AM |
