Converting from Fuel Injection to Carbs, Need Fuel Distrabution help |
Robin914-4 |
Nov 28 2015, 12:06 PM
Newbie Group: Members Posts: 10 Joined: 28-November 15 From: Statesboro, Georgia Member No.: 19,419 Region Association: South East States |
Hey Everybody. I have been searching for an hour with no luck. I have a 1976 914/4 that I have converted over to 44mm Empi's. Now I am setting up the fuel system, new low pressure pump, stainless lines, presure regulator, etc. what I can't figure out is what to do with the extra line I have on the fuel tank. Should I cap it? Vent it? I did run both stainless line back to the engine bay so I could t them in or what ever. I just need some guidance.
Thanks in advance. Robin |
PancakePorsche |
Nov 29 2015, 02:18 AM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
I also agree and highly recommend using pump around method so keep return line in use. Use Holley regulator made for return to tank installed after carbs, not the dead head model before carbs. Set at 3.5 PSI
Lo-Fi Version | Time is now: 2nd June 2024 - 01:33 AM |
