Need a new transmission...so, what gear ratios?, 2.7L |
billh1963 |
Nov 28 2015, 05:40 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
My '72 with a 2.7 six is back.
The engine is running great. However, the gear box is so shitty it's not even worth driving. I've owned a lot of 914's and never had a gearbox so bad. I tried to go for a drive today and made it about 2 miles before I gave up and headed home. I felt like leaving it on the side of the road for the trash collector. Seriously,it's that shitty. The couple times I found second gear it wanted to crunch so I think I'm going to just rebuild it (of course all the shifter bushings and everything related to shifting will be gone through and updated). So, I've looked at several threads and even found some charts of gear ratios/rpm/speeds. For those with a 2.7 or 3.0, did you use the stock ratios? Are you happy with that? What would you change? I'm thinking of changing fifth gear to cruise around 2800-3000 rpm at 70mph. Will that give me enough fan speed to keep the oil cool? I do NOT have an external oil cooler. Tires size is 205/55-16 Any input is appreciated. Thank you |
ConeDodger |
Nov 29 2015, 11:48 AM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
My 901 before the six was a an M/S - 3/4. Preserving the stock 5th gives you an overdrive gear. Though with all of the instrumentation I had it was alarming to watch the head temps rise when cruising in 5th. This was with a Type IV so not sure that would be a problem with a 6...
Lo-Fi Version | Time is now: 9th June 2024 - 10:45 PM |
