Converting from Fuel Injection to Carbs, Need Fuel Distrabution help |
Robin914-4 |
Nov 28 2015, 12:06 PM
Newbie Group: Members Posts: 10 Joined: 28-November 15 From: Statesboro, Georgia Member No.: 19,419 Region Association: South East States |
Hey Everybody. I have been searching for an hour with no luck. I have a 1976 914/4 that I have converted over to 44mm Empi's. Now I am setting up the fuel system, new low pressure pump, stainless lines, presure regulator, etc. what I can't figure out is what to do with the extra line I have on the fuel tank. Should I cap it? Vent it? I did run both stainless line back to the engine bay so I could t them in or what ever. I just need some guidance.
Thanks in advance. Robin |
Dave_Darling |
Nov 30 2015, 06:19 PM
It works better with the t-stat, but the cooling system will still work without it. It will take longer to warm up, of course. But leaving the flaps out sill keep the air from going the places that it is supposed to go, and your engine will not like you for it.
We have seen these engines go from "TOO DAMN HOT" to "normal operating temps" just by installing those flaps. --DD |
SirAndy |
Nov 30 2015, 06:46 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It works better with the t-stat, but the cooling system will still work without it. It will take longer to warm up, of course. But leaving the flaps out sill keep the air from going the places that it is supposed to go, and your engine will not like you for it. We have seen these engines go from "TOO DAMN HOT" to "normal operating temps" just by installing those flaps. (IMG:style_emoticons/default/agree.gif) Without a thermostat the cooling flaps will simply sit in the "full cooling" position which is OK if you're fine with the longer warmup times. However, running an engine without the cooling flaps will result in a quick and ugly heatstroke death. Among other things, running without the flaps means you will have NO air going through your oil cooler. It's a sure way to turn that engine into a boat anchor. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 12:23 AM |
