Converting from Fuel Injection to Carbs, Need Fuel Distrabution help |
Robin914-4 |
Nov 28 2015, 12:06 PM
Newbie Group: Members Posts: 10 Joined: 28-November 15 From: Statesboro, Georgia Member No.: 19,419 Region Association: South East States |
Hey Everybody. I have been searching for an hour with no luck. I have a 1976 914/4 that I have converted over to 44mm Empi's. Now I am setting up the fuel system, new low pressure pump, stainless lines, presure regulator, etc. what I can't figure out is what to do with the extra line I have on the fuel tank. Should I cap it? Vent it? I did run both stainless line back to the engine bay so I could t them in or what ever. I just need some guidance.
Thanks in advance. Robin |
SirAndy |
Nov 30 2015, 06:52 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Here's a pic of what the flaps look like when in the full cooling position.
Note that the passenger side flap is pointing down to direct air into the oil cooler. Without that flap down like that (or no flap at all) none of the air would be forced through the oil cooler. (IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-179-1448931124.1.jpg) |
maf914 |
Dec 1 2015, 07:56 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Here's a pic of what the flaps look like when in the full cooling position. Note that the passenger side flap is pointing down to direct air into the oil cooler. Without that flap down like that (or no flap at all) none of the air would be forced through the oil cooler. (IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-179-1448931124.1.jpg) SirAndy, good picture and explanation. I think it is a common misunderstanding that removal of the flaps will result in less interference to airflow and therefor better cooling. But, as you noted, removal of the flap which directs air to the oil cooler results in the oil cooler no longer doing its job. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:36 PM |
