| Chris Julian |
Sep 23 2004, 09:09 PM
Member ![]() ![]() Group: Members Posts: 159 Joined: 19-March 04 From: SF Bay area Member No.: 1,821 |
Calling all experienced suspension experts.
Just finished installing front Eurothane bushings into the front A arms on my car and I’ve got two questions: 1, How much force should it take to actuate the arm up and down. It takes about 20 lbs to get the arm to budge. Which leads to question #2. I searched the classics and only found info on the back bushings. 2, The front bushing retainers (the ones that actually mount to the body with two bolts) have two positions that they can be bolted in. The retainer is made up of two stamped pieces that are welded together. On one side of the mounting flanges there are two small plates spot welded to the flange, the other side has none. What is the correct side to mount to the body? Thanks, Chris |
| neo914-6 |
Sep 24 2004, 03:25 PM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Chris Julian Suspension Question Sep 23 2004, 09:09 PM
Brett W Chris
The a-arms should not take that much force.... Sep 23 2004, 09:32 PM
Brad Roberts Roller bearings Chris. You will be pissed the firs... Sep 23 2004, 10:56 PM
Mueller needle bearings on a car in England, put on only t... Sep 23 2004, 11:40 PM
SpecialK <... Sep 24 2004, 12:55 AM
SpecialK "Eurothane Bushings" , You running those Jereon? :... Sep 24 2004, 12:58 AM
jim912928 I just put these on my car (twice!). When I t... Sep 24 2004, 06:39 AM
seanery If you come to the Fall Foliage Classic, we're... Sep 24 2004, 07:20 AM
SpecialK <... Sep 24 2004, 09:48 AM
Mueller I just need Seans address again :) Sep 24 2004, 11:10 AM
Bleyseng Where can you buy these fancy Eurothane bushing???... Sep 24 2004, 11:10 AM
Chris Julian You can pick them up in a small town in Germany, I... Sep 24 2004, 02:53 PM
jim912928 I want to win those needle bearings!!... Sep 24 2004, 04:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:52 PM |
