balljoint |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,001 Joined: 6-April 04 Member No.: 1,897 Region Association: None ![]() |
How much should I take off? There are two layers of paint. On top is a crappy colour change to red, underneath the original orange, and in between there are bits of bondo filling in the odd hole. Once I am done with the chassis repairs (and replacing bondo with metal)I am going to POR what I can and then get her painted.
Whatever method I use, should I take it down to bare metal or just to the original primer and let the paint shop take it from there? What kind of surface should I put on the panels for the easiest paint job? This car will never be concours, I just want to fix it right and get the best finish job that I can. |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
Someone once told me to take it down to the original paint color. Something about really good adhesion to the factory paint. Like lapuwali said, many cars had bondo from the factory. If you use a chemical stripper, you almost always have to take off the bondo because of the chemical contamination. Blasting leaves lots of material to shake out for a long time. Ask Sirandy about that. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 3rd July 2025 - 12:39 PM |
