| opera guy |
Sep 24 2004, 08:16 PM
Member ![]() ![]() Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
got no manual so i cant RTFM (read the fXXking manual)...
how much to torque the heat exchanger to the motor? how much to torque the heat exchanger to the muffler? gf prayed, so i didnt strip any heat xchanger studs, whew. thought i "one oomph'd" it, but it's still leaking. so i need the proper specs. also, how much to torque the nut on the valve? (as per valve adjustment) thanks car's coming back together |
| scotty914 |
Sep 25 2004, 04:06 AM
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
two tricks to help heat exchangers to seal :
one take the sealing rings, hang them on a peice of wire and heat em with your propane torch till they are red hot then drop them in to a bucket of water. this will soften them so they deform to the head and heaters with less chance of striping the heads. they will work harden with the temp increase and decrease of the head. two take a long file that will span both inlets of the exchangers at the same time. then just file both surfaces at the same time till they are even and flat with each other. this gives you a good start so you dont have to try to crank them even. scott thacher 75 someday suby power conversion will be completed (IMG:style_emoticons/default/driving-girl.gif) |
opera guy how much to torque heat exchanger to the motor? Sep 24 2004, 08:16 PM
MXMARK Opera guy, I have a manual if you want to borrow i... Sep 24 2004, 10:52 PM
opera guy actually, the heat exchanger nuts are 13 and 14mm.... Sep 25 2004, 12:10 AM
bob91403 Everything I've come across says 12 to 17lbs.,... Sep 25 2004, 01:31 AM
michelko check this out :
http://www.tunacan.net/t4/refere... Sep 25 2004, 02:21 AM
rhodyguy it sounds like you are using the old nuts. a BIG n... Sep 25 2004, 09:19 AM
bob91403 ... Sep 25 2004, 03:17 PM
Ray Warren ... Sep 25 2004, 03:21 PM
bob91403
bob91403 Before you put them back on go to www.casperlabs.c... Sep 25 2004, 04:31 PM
Uraquan
Before you put them back on go to www.casperlabs.... Jan 30 2026, 12:23 PM
JeffBowlsby My engine builder says 14 ft-lbs heat exch to head... Jan 30 2026, 01:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th January 2026 - 05:41 PM |
