| opera guy |
Sep 24 2004, 08:16 PM
Member ![]() ![]() Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
got no manual so i cant RTFM (read the fXXking manual)...
how much to torque the heat exchanger to the motor? how much to torque the heat exchanger to the muffler? gf prayed, so i didnt strip any heat xchanger studs, whew. thought i "one oomph'd" it, but it's still leaking. so i need the proper specs. also, how much to torque the nut on the valve? (as per valve adjustment) thanks car's coming back together |
| Ray Warren |
Sep 25 2004, 03:21 PM
Member ![]() ![]() Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
QUOTE(bob91403 @ Sep 25 2004, 04:17 PM) QUOTE(michelko @ Sep 25 2004, 12:21 AM) check this out : http://www.tunacan.net/t4/reference/torque.htm very informative site!! (IMG:style_emoticons/default/smilie_flagge6.gif) Thanks, only place I've seen with an actual list. Of course you don't know where he got the info. I think you can trust this information without any hesitation. |
opera guy how much to torque heat exchanger to the motor? Sep 24 2004, 08:16 PM
MXMARK Opera guy, I have a manual if you want to borrow i... Sep 24 2004, 10:52 PM
opera guy actually, the heat exchanger nuts are 13 and 14mm.... Sep 25 2004, 12:10 AM
bob91403 Everything I've come across says 12 to 17lbs.,... Sep 25 2004, 01:31 AM
michelko check this out :
http://www.tunacan.net/t4/refere... Sep 25 2004, 02:21 AM
scott thacher two tricks to help heat exchangers to seal :
one ... Sep 25 2004, 04:06 AM
rhodyguy it sounds like you are using the old nuts. a BIG n... Sep 25 2004, 09:19 AM
bob91403 ... Sep 25 2004, 03:17 PM
bob91403
bob91403 Before you put them back on go to www.casperlabs.c... Sep 25 2004, 04:31 PM
Uraquan
Before you put them back on go to www.casperlabs.... Jan 30 2026, 12:23 PM
JeffBowlsby My engine builder says 14 ft-lbs heat exch to head... Jan 30 2026, 01:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th January 2026 - 05:42 PM |
