| opera guy |
Sep 24 2004, 08:16 PM
Member ![]() ![]() Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
got no manual so i cant RTFM (read the fXXking manual)...
how much to torque the heat exchanger to the motor? how much to torque the heat exchanger to the muffler? gf prayed, so i didnt strip any heat xchanger studs, whew. thought i "one oomph'd" it, but it's still leaking. so i need the proper specs. also, how much to torque the nut on the valve? (as per valve adjustment) thanks car's coming back together |
| bob91403 |
Sep 25 2004, 03:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 15-September 04 From: Los Angeles, CA Member No.: 2,763 |
QUOTE(914ray @ Sep 25 2004, 01:21 PM) QUOTE(bob91403 @ Sep 25 2004, 04:17 PM) QUOTE(michelko @ Sep 25 2004, 12:21 AM) check this out : http://www.tunacan.net/t4/reference/torque.htm very informative site!! (IMG:style_emoticons/default/smilie_flagge6.gif) Thanks, only place I've seen with an actual list. Of course you don't know where he got the info. I think you can trust this information without any hesitation. No doubt. Looking at his site further leads me to believe he's done extensive research on the subject. This guy knows his stuff. |
opera guy how much to torque heat exchanger to the motor? Sep 24 2004, 08:16 PM
MXMARK Opera guy, I have a manual if you want to borrow i... Sep 24 2004, 10:52 PM
opera guy actually, the heat exchanger nuts are 13 and 14mm.... Sep 25 2004, 12:10 AM
bob91403 Everything I've come across says 12 to 17lbs.,... Sep 25 2004, 01:31 AM
michelko check this out :
http://www.tunacan.net/t4/refere... Sep 25 2004, 02:21 AM
scott thacher two tricks to help heat exchangers to seal :
one ... Sep 25 2004, 04:06 AM
rhodyguy it sounds like you are using the old nuts. a BIG n... Sep 25 2004, 09:19 AM
bob91403 ... Sep 25 2004, 03:17 PM
Ray Warren ... Sep 25 2004, 03:21 PM
bob91403 Before you put them back on go to www.casperlabs.c... Sep 25 2004, 04:31 PM
Uraquan
Before you put them back on go to www.casperlabs.... Jan 30 2026, 12:23 PM
JeffBowlsby My engine builder says 14 ft-lbs heat exch to head... Jan 30 2026, 01:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th January 2026 - 05:40 PM |
