2.0 Type IV Vintage Race Engine |
jdahl |
Dec 5 2015, 10:16 PM
Newbie Group: Members Posts: 10 Joined: 16-September 10 From: Peoria, IL Member No.: 12,179 Region Association: Upper MidWest |
I'm building an engine (2 actually) to run in my 914 for SVRA Group 3 road racing. I've done a lot of research, built a spreadsheet, shopped around, done more research, etc. Before I start spending money on parts, I would appreciate any experienced advice/critique of my build(s).
Conservative Bore 94 mm - flat top Type 1 "stroker" pistons 35mm pin height Stroke 71 mm Rods 5.325" Heads 59 cc, 2.0 42/36 valves, single valve springs (porting/polishing TBD) Rod Ratio 1.905:1 Deck Height .04" (1mm) Compression Ratio 8.5:1 Cam 86a Creative Bore 95 mm - 14cc custom dome pistons 25.8mm pin height Stroke 71 mm Rods 5.7" Heads 56 cc, 2.0 44/38 valves, double valve springs (ported/polished) Rod Ratio 2.039:1 Deck Height .04" (1mm) Compression Ratio 11.5:1 Cam 86b/c or 163/86b Induction Weber 40 IDF Exhaust Kerry Hunter 1.5" header Again, I appreciate any and all constructive feedback. |
stugray |
Dec 18 2015, 08:12 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I guess it depends on the club then.
If you check race times for rocky mountian vintage racing rmvr.com you would see that Jason Cobb is consistently the fastest car in the small bore run group and it is a 4-cyl. http://www.mylaps.com/en/events/1141246#_g...7206.1450490374 RMVR SPRING RACE GRAND PRIX, GROUP 3 SMALL BORE PRODUCTION |
Lo-Fi Version | Time is now: 29th May 2024 - 12:33 AM |
