2.0 Type IV Vintage Race Engine |
jdahl |
Dec 5 2015, 10:16 PM
Newbie Group: Members Posts: 10 Joined: 16-September 10 From: Peoria, IL Member No.: 12,179 Region Association: Upper MidWest |
I'm building an engine (2 actually) to run in my 914 for SVRA Group 3 road racing. I've done a lot of research, built a spreadsheet, shopped around, done more research, etc. Before I start spending money on parts, I would appreciate any experienced advice/critique of my build(s).
Conservative Bore 94 mm - flat top Type 1 "stroker" pistons 35mm pin height Stroke 71 mm Rods 5.325" Heads 59 cc, 2.0 42/36 valves, single valve springs (porting/polishing TBD) Rod Ratio 1.905:1 Deck Height .04" (1mm) Compression Ratio 8.5:1 Cam 86a Creative Bore 95 mm - 14cc custom dome pistons 25.8mm pin height Stroke 71 mm Rods 5.7" Heads 56 cc, 2.0 44/38 valves, double valve springs (ported/polished) Rod Ratio 2.039:1 Deck Height .04" (1mm) Compression Ratio 11.5:1 Cam 86b/c or 163/86b Induction Weber 40 IDF Exhaust Kerry Hunter 1.5" header Again, I appreciate any and all constructive feedback. |
Brett W |
Dec 18 2015, 08:55 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
You guys should head east next April for the Walter Mitty Historics at RD Atlanta next spring. You will have a blast running with those guys.
Lo-Fi Version | Time is now: 28th May 2024 - 11:35 PM |
