Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
A customer of mine in is doing a 67 912 resto from tub up. The early 912s had the same issues with rust we do and even has foam in them too (just like our 914s).
He used a company in Ohio to dip the car and dissolve the crud (he did scrape off the tar) ans ecoat the entire car. He did the doors 1st to see if he would like the results, and wow! Looks like new metal. Looks like Stoddard will be doing a full write up on this car at some point, but I was so impressed with the results that though I would share. Attached thumbnail(s) ![]() ![]() ![]() |
Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,274 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
If you did a 914, you would first want to cut the outer longs off your car (and of course properly support the car before doing that). The heater tubes inside will get destroyed by the dipping process, not to mention the e-coating process.
Lo-Fi Version | Time is now: 12th July 2025 - 03:21 PM |
