| jmill |
Dec 22 2015, 02:23 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Looking to buy some Euromeisters and all I see is 7's and 9's in 17" rims. Do the 17x9's fit in the rear with AA steel flares? If not, do they need major work (grafting in metal) or just some tugging.
| Steve |
Dec 22 2015, 02:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,026 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I'm running Fixse 17x9. I have no problems fitting 245x40x17 street tires on the rear
255 will also fit if they don't have the curb rash rib on them. |
jmill AA Steel Flares and 17x9's in Rear Dec 22 2015, 02:23 PM
mepstein Are you sure you want big heavy wheels that don... Dec 22 2015, 02:32 PM
bfrymire I have the same rims, except they are 16x9. And t... Dec 22 2015, 02:37 PM
SirAndy Do the 17x9's fit in the rear with AA steel fl... Dec 22 2015, 03:06 PM
snakemain 17x9s Rota Fox Fuchs reps with 245/40 in the rear ... Dec 22 2015, 03:29 PM
Series9 The RS has 17x9 Cup IIs with 255 rubber.
We rolle... Dec 22 2015, 03:34 PM
andys
We roll... Dec 22 2015, 06:52 PM
rick 918-S John, I have a 10mm spacer on the rear to clear th... Dec 22 2015, 03:49 PM
Elliot Cannon Spacered to fit. QRS fiberglass fenders. 17X9. Dec 22 2015, 04:05 PM
jmill
Are you sure you want big heavy wheels that don... Dec 22 2015, 04:32 PM
rick 918-S
Are you sure you want big heavy wheels that don... Dec 22 2015, 09:39 PM
jmill
17x9s Rota Fox Fuchs reps with 245/40 in the rear... Dec 22 2015, 04:47 PM
snakemain
17x9s Rota Fox Fuchs reps with 245/40 in the rea... Dec 22 2015, 06:54 PM
jmill Rear offset is 16mm. I believe that is stock 911 ... Dec 22 2015, 04:54 PM
Cracker John - I'd take the subjective opinion that 17... Dec 22 2015, 05:18 PM
jmill Tony, are those the RSR finish Rota Foxes? If so ... Dec 22 2015, 05:44 PM
pete000 I agree the 17's are just too big for the 914.... Dec 22 2015, 05:53 PM
Cracker They may be the same but mine are called Linea Cor... Dec 22 2015, 05:53 PM
bfrymire Cracker,
Your flares look different than mine, lo... Dec 22 2015, 06:24 PM
Cracker Brett - Yes. Mine are modified/custom. Also, the H... Dec 22 2015, 07:40 PM
sixnotfour ya 17's suck, bahahaha!!
last pic 15... Dec 22 2015, 07:23 PM
whitetwinturbo ...........more ugly 17's :confused: ?
Dec 22 2015, 07:33 PM
Steve
I l... Dec 22 2015, 09:30 PM
whitetwinturbo
I ... Dec 23 2015, 01:23 PM
sixnotfour i do luv my 15 x8 x9
that is 245/50 x 15 re71... Dec 22 2015, 07:47 PM
rick 918-S
that is 245/50 x 15 re71... Dec 22 2015, 09:46 PM
jmill They do look good but tire selection in the 15 and... Dec 23 2015, 10:51 AM
d914 with 9 in wide rims I believe the offset should be... Dec 23 2015, 12:19 PM
PotterPorsche Rota fox -euromiesters same thing right?
http://w... Dec 24 2015, 10:13 AM
jmill
Yes a... Dec 24 2015, 06:46 PM
Cracker I bought mine from Wheeldude.com - I might of over... Dec 24 2015, 06:55 PM
carr914 RE: AA Steel Flares and 17x9's in Rear Dec 25 2015, 05:21 AM
Garland Euromeister 16x9 15mm ET, AA steel flares. 245-50x... Dec 25 2015, 08:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 18th March 2026 - 07:27 AM |
