69-74 911,914, 915 Type ZF Limited Slip Differential. |
Martin Baker |
Dec 21 2015, 08:57 PM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
1969-1974 911,914 or early 915 type trans-axle, ZF PORSCHE limited slip differential.
$3000.00 Not NOS but close. This unit was more than likely purchased as a replacement unit by someone, and not taken from a trans-axle that had been removed from a known car. I am going to use the Guard GT LSD, so I must to sell this one. I do not have the correct out drives for it, and are difficult to locate. I sent this unit to Gordon Ledbetter, owner of OREGON RENNSPORT LLC, who is well versed in the 911/914/915 ZF LSD unit, for inspection and repair. Based on what he found during inspection, he believes that it was only installed and ran very little, less than 100 miles, or never run at all, only installed, so it has had a ring gear bolted to it, it has been in a trans-axle, a 914 trans-axle I bought a few years back. If I had to guess, the trans-axle was built up, then stored until I bought it. >> Gordon provided me with multiple photos of the internal parts and found it to be set up 80%, with no wear to the internals. He reassembled it to the 80% @ 60 pounds pre-load, flange to flange. My asking price is based on two experts in the PORSCHE trans-axle business. > I will insist on shipping insurance, due to loss or damage to such a rare part. No choice. Shipping is costly due to the parts weight. Inquires welcome Attached thumbnail(s) |
Martin Baker |
Dec 23 2015, 11:07 PM
Here is INFO OVERLOAD courtesy of Armando Serrano.
P/N 914.332.209.00 http://www.early911sregistry.org/forums/sh...ip-Differential |
rgalla9146 |
Dec 24 2015, 04:36 PM
Advanced Member Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Here is INFO OVERLOAD courtesy of Armando Serrano. P/N 914.332.209.00 http://www.early911sregistry.org/forums/sh...ip-Differential Martin Just FYI when installed in an early 915 (in a 911 chassis) the output flange is part # 919 332 210 01 which is a larger diameter item, 110mm vs. 94mm, this info may be helpful to your prospects. Don't bum out, this is a very desirable item. Also, I believe that standard 914 flanges can be machined to the same dimensions as the LSD ones. Seek qualified advise. The only difference would be the driveshafts and CVs will have to extend 5mm more toward the gearbox on each side. |
Lo-Fi Version | Time is now: 17th June 2024 - 06:14 AM |
