D-Jet FI trigger points |
TheIronSausage |
Dec 22 2015, 09:44 PM
Newbie Group: Members Posts: 4 Joined: 14-June 15 From: 22601 Member No.: 18,851 Region Association: MidAtlantic Region |
Hi all,
I'm working on a '76 914. It's encumbered by being controlled by the malady that is D-Jetronic. Like every other important component in the system, the fuel injection trigger points seem to impossible to source. I've searched around, and found an article on this site suggesting Volvo sources. That article was from 2011, and I have a D-Jet Volvo, and was unable to find points or any other parts for it two years ago. That Volvo now wears a set of SU carbs as a result. The customer seems insistent on keeping his car as original as possible. In concept I have no problems with that request, but in practice, parts are hard to find, and expensive when found. Do any of you fine folk have a source for these? I'd greatly appreciate any help. Thanks, Matt |
TheIronSausage |
Dec 26 2015, 11:11 AM
Thanks all for your responses. I would try adjusting the ones I have, but they're essentially rusted over from sitting in a super dank warehouse for so long. (914 sixer, PM sent).
So, I'm dying to know. Why do you guys love D-Jet so much? Let me start by saying that I've worked as a vintage sportscar mechanic for about a decade, and I'm familiar with and able to diagnose everything from D-Jet to Motronic, even Lucas Opus. I'm not normally the kind of guy to just slap a set of carbs on a failing injection system. However, every D-Jet car I've starting working on has needed several parts that have to be scrounged in used condition, and in the case of Volvos, at a high cost... For a part that's used, 40 years old, and with no warranty. I've driven Benzes, 914s, and Volvo 1800s and 140s with D-Jet. Some of them ran as they should, and they were fine to live with and were reliable. But they didn't perform any better than my Volvo that I've converted to SUs, and barely maintain. I've spent hours and hours tuning the D-Jet system in a Volvo 1800 to run well despite not having a functioning IAC ($250 used part). It turned out very well in the end. The car wanted a little extra gas for the first five minutes, and then it'd settle down to 800 RPM every time. It never stalled, and pulled fairly hard at WOT.. I can't say it was worth all the time I ate in the process to get the same driveability I've gotten from an hour rebuilding a set of SUs, and an hour of tuning to the car. That customer sold his car when the MAP sensor (affectionately dubbed the grenade by Volvo guys) died on him, and the cheapest one we could find was over $400 for either a used, or questionably "rebuilt" one. When something goes wrong with D-Jet, it can be hours of troubleshooting resistances through the harness, checking components, and finding vacuum leaks. This is the same with L-Jet for instance, but that system is way less susceptible to it's environment, and better built. I get originality. In terms of everyday use, I as a mechanic can't tell why someone would want to live with questionable reliability, and a dwindling supply of parts to manage their engine's fuel delivery. I'm no parts hanger, I rebuild everything I can, and reverse engineer a lot of stuff. But few things make me grumble like seeing a D-Jet car come in on a rollback. Working on SPICA Alfas is up there.. At any rate, I don't want to piss in any of your Cheerios. I'm genuinely interested to understand the loyalty behind such an antiquated, and easily replaceable system. Matt |
saigon71 |
Dec 26 2015, 06:04 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Thanks all for your responses. I would try adjusting the ones I have, but they're essentially rusted over from sitting in a super dank warehouse for so long. (914 sixer, PM sent). So, I'm dying to know. Why do you guys love D-Jet so much? Let me start by saying that I've worked as a vintage sportscar mechanic for about a decade, and I'm familiar with and able to diagnose everything from D-Jet to Motronic, even Lucas Opus. I'm not normally the kind of guy to just slap a set of carbs on a failing injection system. However, every D-Jet car I've starting working on has needed several parts that have to be scrounged in used condition, and in the case of Volvos, at a high cost... For a part that's used, 40 years old, and with no warranty. I've driven Benzes, 914s, and Volvo 1800s and 140s with D-Jet. Some of them ran as they should, and they were fine to live with and were reliable. But they didn't perform any better than my Volvo that I've converted to SUs, and barely maintain. I've spent hours and hours tuning the D-Jet system in a Volvo 1800 to run well despite not having a functioning IAC ($250 used part). It turned out very well in the end. The car wanted a little extra gas for the first five minutes, and then it'd settle down to 800 RPM every time. It never stalled, and pulled fairly hard at WOT.. I can't say it was worth all the time I ate in the process to get the same driveability I've gotten from an hour rebuilding a set of SUs, and an hour of tuning to the car. That customer sold his car when the MAP sensor (affectionately dubbed the grenade by Volvo guys) died on him, and the cheapest one we could find was over $400 for either a used, or questionably "rebuilt" one. When something goes wrong with D-Jet, it can be hours of troubleshooting resistances through the harness, checking components, and finding vacuum leaks. This is the same with L-Jet for instance, but that system is way less susceptible to it's environment, and better built. I get originality. In terms of everyday use, I as a mechanic can't tell why someone would want to live with questionable reliability, and a dwindling supply of parts to manage their engine's fuel delivery. I'm no parts hanger, I rebuild everything I can, and reverse engineer a lot of stuff. But few things make me grumble like seeing a D-Jet car come in on a rollback. Working on SPICA Alfas is up there.. At any rate, I don't want to piss in any of your Cheerios. I'm genuinely interested to understand the loyalty behind such an antiquated, and easily replaceable system. Matt Hi Matt: Sorry to hear about your D-jet experience with Volvo's. My experience has been completely different with D-Jet in a 2.0 914. This car serves as my daily driver 9 months out of the year. It's not a perfect system...but once sorted out, I've found it to provide excellent power, reliability, economy, and overall drivability. One tap of the ignition and it's running, each and every time. You bring up some fair points about parts availability...but that is changing too. Jeff Bowlsby makes new D-jet FI wiring harnesses and Tangerine Racing has produced a rebuild kit that includes a new diaphragm for the MPS's. Dave Sprinkle makes new TPS boards. This being said, I'm still putting together a spare of each FI component to take with me on road trips just in case. I'm not anti-carb or stuck on originality. Other FI alternatives are out there for our Type 4 engines...but they are not cheap either. Quite simply, D-Jet has served me well. Hopefully this sheds some light on your question (at least in my case). Maybe it's just our differing experiences that cause our differing opinions on the D-jet. Cheers! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 04:23 AM |
