> Header sizing 914-6
mb911
post Dec 27 2015, 02:21 PM
So while my 914-6 oil tanks are being machined I going to start working through my header with heat exhanger design out of stainless.. I do not have non compete on these with m&k so that gives me design freedom.. However I will use similar design process as the m&k/ rarlyl8 design. So my question is 1.5" the most common size or allot of you using 1.625
Mark Henry
post Dec 28 2015, 08:27 AM
that's what I do!
1-1/2" up to 2.7
1-5/8" or 1 3/4" for 3.0 and 3.2, stock I'd use the 1 5/8" and use the bigger for HP.
But that said, although there would obviously be a bit of power loss, even a stock 3.2 runs fine on factory heat exchangers with are IIRC only about 1 3/8".
mb911   Header sizing 914-6   Dec 27 2015, 02:21 PM
Steve   Most common aftermarket is 1 5/8" OD for 3.2 ...   Dec 27 2015, 02:29 PM
mepstein   I would like 1 5/8 for my 3.2. I want your first s...   Dec 27 2015, 03:38 PM
Dion   I'll be in for a set. Would be for a 2.4L Ri...   Dec 27 2015, 03:48 PM
wndsnd   If these have heat, I would like to see what they ...   Dec 27 2015, 05:25 PM
jmill   From Dempsey's book 2.0-2.4 = 1 1/2 or 1 5/8 ...   Dec 27 2015, 07:30 PM
mb911   From Dempsey's book 2.0-2.4 = 1 1/2 or 1 5/8...   Dec 28 2015, 05:49 AM
Mark Henry   1-1/2" up to 2.7 1-5/8" or 1 3/4" f...   Dec 28 2015, 08:27 AM
JmuRiz   My 2.7 was spec'd out at 1 5/8 by MSDS. I...   Dec 28 2015, 08:28 AM
Steve   My 2.7 was spec'd out at 1 5/8 by MSDS. I...   Dec 28 2015, 10:30 AM
jmill   I need to come pick up that engine shortly Com...   Dec 28 2015, 08:50 AM
wndsnd   Is there an accepted ratio between exhaust port si...   Dec 28 2015, 05:27 PM
jmill   Is there an accepted ratio between exhaust port s...   Dec 28 2015, 05:57 PM
mb911   Is there an accepted ratio between exhaust port ...   Dec 28 2015, 06:25 PM
mepstein   [quote name='jmill' post='2282534' date='Dec 28 2...   Dec 28 2015, 07:19 PM
mb911   [quote name='jmill' post='2282534' date='Dec 28 ...   Dec 28 2015, 07:39 PM
JmuRiz   Good point.. Well guess I will have to solve that...   Dec 30 2015, 09:10 AM
jmill   Smaller engines already have the stock he's. ...   Dec 28 2015, 09:45 PM
eitnurg   Many (too many) years ago I had a Euro 3.2 and sta...   Dec 29 2015, 03:40 AM
Mark Henry   One thing I haven't seen discussed is the othe...   Dec 29 2015, 06:32 AM
wndsnd   Good information, those heads have 40mm exhaust va...   Dec 29 2015, 11:13 AM
mepstein   These. Open pipe. No baffle. No exhaust. Turn the ...   Dec 29 2015, 12:02 PM
mb911   After the headers with heat are done. I will be wo...   Dec 29 2015, 12:17 PM
Steve   Any idea what the cost will be for 1 5/8" hea...   Dec 29 2015, 12:40 PM
mb911   Any idea what the cost will be for 1 5/8" he...   Dec 29 2015, 02:54 PM
Mark Henry   Any idea what the cost will be for 1 5/8" h...   Dec 29 2015, 03:56 PM
brant   I can't wait to see them and the cost also I...   Dec 29 2015, 01:24 PM
Travis Neff   nice price!   Dec 29 2015, 04:55 PM
mb911   nice price! I hope I can make it happen th...   Dec 29 2015, 05:05 PM
wndsnd   Sounding good. Would a rounder style heater box l...   Dec 29 2015, 05:04 PM
mb911   Sounding good. Would a rounder style heater box ...   Dec 29 2015, 05:07 PM
wndsnd   Got it.   Dec 29 2015, 05:13 PM
mb911   Any feed back on the 914-6 vs 4cyl muffler bracket...   Dec 29 2015, 06:23 PM
Travis Neff   914-6 headers and OE heat exchangers can use the 2...   Dec 29 2015, 06:26 PM
mepstein   Make up something cool from ss. I have an England ...   Dec 29 2015, 06:41 PM
Travis Neff   and by 2.0, I mean the 4 cyl 2.0 bracket   Dec 29 2015, 07:17 PM
Travis Neff   If you wanted to do something cool, one that would...   Dec 29 2015, 07:18 PM
Steve   I'm running factory six heat exchangers, with ...   Dec 29 2015, 07:24 PM
mepstein   England hanger   Dec 30 2015, 09:15 AM
Mueller   England hanger I'd ditch the welded-on stif...   Dec 30 2015, 09:23 AM
mb911   Looks like I have c.. So the question is the heigh...   Dec 30 2015, 12:45 PM
gandalf_025   Any chance you can make some simple ones like thes...   Dec 30 2015, 02:51 PM
mb911   Any chance you can make some simple ones like the...   Dec 30 2015, 03:50 PM
Gary   Any chance you can make some simple ones like the...   Dec 31 2015, 12:03 PM
mb911   Who made this originally?   Dec 30 2015, 03:50 PM
gandalf_025   Who made this originally? Not entirely sure who...   Dec 30 2015, 04:33 PM
wndsnd   [quote name='mb911' post='2283324' date='Dec 30 2...   Dec 30 2015, 04:59 PM
mb911   [quote name='mb911' post='2283324' date='Dec 30 ...   Dec 30 2015, 05:23 PM
mb911   [quote name='mb911' post='2283324' date='Dec 30 2...   Dec 30 2015, 05:24 PM
jmill   Looks like I have c.. So the question is the heig...   Dec 30 2015, 04:49 PM
jmill   England hanger I'd ditch the welded-on sti...   Dec 30 2015, 04:55 PM
mb911   Picked up the engine today thanks John. Going to b...   Dec 31 2015, 02:40 PM
JmuRiz   They aren't the same, the heights are differen...   Dec 31 2015, 02:52 PM
mb911   They aren't the same, the heights are differe...   Dec 31 2015, 03:00 PM
Luke M   You would need a 914-6/914 2.0 bracket . There...   Dec 31 2015, 05:25 PM
jmill   OK, I thought I had a couple of 2.0 muffler hanger...   Dec 31 2015, 06:10 PM
Luke M   OK, I thought I had a couple of 2.0 muffler hange...   Dec 31 2015, 06:16 PM
mb911   OK, I thought I had a couple of 2.0 muffler hang...   Jan 4 2016, 03:34 PM
jd74914   Thanks for the info. I will mod my mount and sta...   Jan 4 2016, 09:21 PM
mb911   Thanks for the info. I will mod my mount and st...   Jan 5 2016, 06:11 AM
jd74914   By simpler collector do you mean a formed collec...   Jan 5 2016, 01:42 PM
mb911   [quote name='mb911' post='2285682' date='Jan 5 20...   Jan 5 2016, 03:32 PM
jd74914   I think I know what you're talking about bu...   Jan 6 2016, 12:32 PM
396   [quote name='mb911' post='2285682' date='Jan 5 2...   Mar 14 2016, 07:13 PM
wndsnd   Design and build the best performance and quality ...   Jan 4 2016, 04:47 PM
Eric_Shea   It began to rain in Baton Rouge and it continued t...   Jan 4 2016, 06:38 PM
porschetub   It began to rain in Baton Rouge and it continued ...   Jan 5 2016, 03:14 AM
Cairo94507   I would love a set of SS headers for my 3.2 with h...   Jan 4 2016, 11:13 PM
JmuRiz   FYI I was looking at Armondo's 914/6 GT site a...   Jan 5 2016, 01:19 PM
Justinp71   Another option to heat exchangers is seat warmers....   Jan 5 2016, 02:50 PM
mepstein   Another option to heat exchangers is seat warmers...   Jan 5 2016, 06:22 PM
wndsnd   Updates?   Jan 10 2016, 01:31 PM
mb911   Updates? Sorry been finishing the oil tanks up...   Jan 10 2016, 01:36 PM
wndsnd   Watching both keenly! :)   Jan 10 2016, 02:15 PM
mb911   Well I have refined the oil tank process so I shou...   Mar 14 2016, 01:46 PM
JmuRiz   Sounds good to me, 6 weeks seems pretty quick to m...   Mar 14 2016, 01:50 PM
mb911   So this project is going to start soon but I have ...   Jul 8 2016, 10:39 AM
wndsnd   I would consider that... I am dreading late Fall....   Jul 8 2016, 11:00 AM
JmuRiz   If they work with Marty's (MSDS) headers, I...   Jul 8 2016, 01:31 PM
gereed75   I actually think the idea of a heat plenum that wo...   Jul 8 2016, 02:13 PM
mb911   I actually think the idea of a heat plenum that w...   Jul 8 2016, 02:32 PM
mb911   What I would need is a set to model off of. Anyone...   Jul 8 2016, 02:32 PM
gereed75   I have an old set of what I think are Burschs that...   Jul 8 2016, 02:58 PM
Perry Kiehl Clone   I tried to get factory 6 HE's reproduced about...   Jul 8 2016, 11:26 PM
mb911   Agreed I made hundreds of sets of headers for rarl...   Jul 9 2016, 05:58 AM
Perry Kiehl Clone   You can't make heat exchangers out of mild ste...   Jul 9 2016, 07:53 AM
mb911   with the 911 market we made the heat exchangers ou...   Jul 9 2016, 08:07 AM
mb911   Another thought I just had as I was looking at my ...   Jul 9 2016, 12:36 PM
mepstein   Another thought I just had as I was looking at my...   Jul 9 2016, 01:39 PM
Perry Kiehl Clone   Another thought I just had as I was looking at my...   Jul 9 2016, 04:51 PM
bahnzai   Ben, I have a factory set of 914-6 exhaust I will ...   Jul 9 2016, 01:52 PM
mb911   Way better . This was a common upgrade for 3.2 car...   Jul 9 2016, 07:49 PM
396   Way better . This was a common upgrade for 3.2 ca...   Jul 10 2016, 12:19 AM
mb911   I do.   Jul 10 2016, 05:18 AM
JmuRiz   :D Interesting about the 3.6 heat exchangers...Sc...   Jul 10 2016, 06:43 PM
mb911   Quick update as I work one the Gt steel rocker fla...   Aug 21 2016, 02:22 PM
Eric_Shea   (2) Pair please. :D   Aug 21 2016, 04:05 PM
restore2seater   Any estimate on GB cost?   Aug 21 2016, 06:08 PM
raynekat   I'm interested in a set of 1-5/8" heat ex...   Aug 22 2016, 12:36 AM
mb911   Target for group buy is 1500.. I will firm this up...   Aug 22 2016, 05:36 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:19 PM
