Bucking with initial acceleration, D-Jet |
Montreal914 |
Dec 31 2015, 06:05 PM
Senior Member Group: Members Posts: 1,571 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I've been trying to solve an issue that makes the driving rather unpleasant (IMG:style_emoticons/default/headbang.gif)
I have a 2056 D-Jet that I daily drive. Recently I replaced the fuel filter and since then, the car has developed this behavior which I don't see why it would be related. When I put in first gear and get going, the car doesn't pick up and is bucking. As I progressively press on the pedal, it suddenly picks up and gets going normally. While it's trying to get going, I've noticed that my A/F gauge tends to go lean and out of range. Things that came to my mind: faulty throttle switch which influences the fuel delivery, hence lean. On the TPS, I checked the open/close circuit of the 2 traces with the 10 switches and everything is good. Idle switch kicks in also. I checked the resistance of the whole D-Jet harness on the 25 pin connector at the CPU as suggested by Anders and everything is within range. Replaced the points and adjusted Dwell. Fuel pressure is set at 29psi (analog gauge inline). I swapped the TPS, the CPU, the MPS, the coil without any improvement. I'm running out of ideas... (IMG:style_emoticons/default/sad.gif) Maybe someone has experienced something like this (IMG:style_emoticons/default/confused24.gif) |
Mblizzard |
Jan 2 2016, 09:54 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
What year is the motor? If it is a 73 then the Ballast Resistor might be an issue. Try adding a 1000 ohm variable resistor to the CHT. Radio Shack volume control and see what varying the resistance starting at 270 ohm does.
Lo-Fi Version | Time is now: 1st June 2024 - 08:20 AM |
