> 1971 914-4 Frankenstein, w/ 912E 2.0 L-Jet FI?
mikesjunk
post Dec 20 2015, 05:39 PM
Ok so I'm working on a 1971 914-4 which from another thread it appears to have a 75-76 2.0 912E L-Jet FI system on it from the PO.
I have plumbed new fuel lines through out the car, cleaned fuel tank and it has fresh gas.
I went through the dual relay and redid it all which I did find one wire on the wrong terminal from the diagram I had.
The previous symptom was that it would start and then die when the key was released. So I threw a battery in it and yep that's what it does. It will fire and run momentarily then die.
First issue is that I don't hear the fuel pump run. It's currently wired from the original harness with some PO adds ons like a fuse. It is not wired to the dual relay but back into the harness that runs to the relay box. I put a meter on it while testing and didn't ever see any voltage. So to make sure this wasn't the issue I hot wired it to run off the battery while I tested that. But that didn't fix the main issue.
Next item is that the ignition switch looks like it's from the movies and has been hot wires. Of course they did it through and around the knee pad so I'm digging into that now. I unwired it so I could remove the knee pad.
From the ignition switch area there looks like 4 wires. red, red/black stripe, a black and a gray. The gray one wasn't hooked to anything.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikesjunk.com-19423-1450654793.1.jpg)
From the harness there were 5 wires. The Black/Yellow and Blue/Yellow weren't hooked to anything.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikesjunk.com-19423-1450654793.2.jpg)
I'll start researching the wiring diagrams but anyone want to post a response to short cut this would be appreciated.
Also the key/cylinder feels pretty bad so anyone recommend someone who can go through it? I saw a guy on ebay listing this but looking for recommendations as it will need something eventually.
mikesjunk
post Jan 3 2016, 05:58 PM
And the Frankenstein continues. The injector numbers were 280 150 116 so it's part Beetle also.
So the test was 75% good. (IMG:style_emoticons/default/smile.gif) Three of the four injectors seemed to work and had decent spray pattern. One only clicked and dribbled. The list of things to fix keeps growing.
So the dilemma....what to do with injectors.
mikesjunk   1971 914-4 Frankenstein   Dec 20 2015, 05:39 PM
rick 918-S   If it cranks and fires with the key that's goo...   Dec 20 2015, 06:47 PM
steuspeed   The key cylinders are fairly simple. It may just n...   Dec 20 2015, 07:00 PM
mikesjunk   I did check voltage at the coil and it stays at 12...   Dec 20 2015, 07:41 PM
914Sixer   70-71 ignition column was sourced from the VW Type...   Dec 20 2015, 07:42 PM
r_towle   Ok, You mention dual relay, that is Ljet fuel inj...   Dec 20 2015, 08:42 PM
mikesjunk   http://www.914world.com/bbs2/index.php?act...=2...   Dec 20 2015, 09:14 PM
mikesjunk   Additional info. http://www.914world.com/bbs2/upl...   Dec 23 2015, 02:15 PM
ndfrigi   the 2nd time I did fix something underneath the fu...   Dec 23 2015, 02:52 PM
mikesjunk   I already found the kinked line under the tank. :...   Dec 23 2015, 06:21 PM
914fahrer   I already found the kinked line under the tank. ...   Dec 24 2015, 06:35 AM
timothy_nd28   Nice chart, but I see some red flags. I'm curi...   Dec 23 2015, 11:28 PM
mikesjunk   Thanks for stopping by Tim. The chart is basicall...   Dec 24 2015, 08:53 AM
r_towle   Tim is the man   Dec 24 2015, 11:40 AM
timothy_nd28   Very interesting! I am not good with part num...   Dec 24 2015, 11:40 AM
timothy_nd28   Rich, you made my wife LOL last night after she re...   Dec 24 2015, 11:54 AM
mikesjunk   LOL, it seems to be a matter of perspective. Gues...   Dec 24 2015, 12:23 PM
mikesjunk   Here are the full bay shots. http://www.914world....   Dec 24 2015, 12:26 PM
timothy_nd28   I'll turn a blind eye to your fuel delivery...   Dec 24 2015, 12:56 PM
mikesjunk   For Pin 13 yes it was to ground and I also did it ...   Dec 24 2015, 02:16 PM
timothy_nd28   Good, applying power straight to the coil with the...   Dec 24 2015, 02:34 PM
timothy_nd28   This is a true Frankenstein! Pin 12 should no...   Dec 24 2015, 03:27 PM
mikesjunk   7 pin AFM Here's a photo of the temp sender. ...   Dec 24 2015, 04:40 PM
mikesjunk   Throttle Switch Ok so here's what the pigtail...   Dec 24 2015, 05:31 PM
Jeff Bowlsby   I should go back a reread this whole thread...bizz...   Dec 24 2015, 07:09 PM
mikesjunk   Thanks Jeff, I've already been on your site a ...   Dec 24 2015, 07:19 PM
mikesjunk   Hope everyone has been having a good holiday's...   Dec 31 2015, 04:26 PM
mikesjunk   Note to self: Don't use a cheap meter for tro...   Jan 2 2016, 01:11 PM
Dave_Darling   L-jet should use the dual relay to run the fuel pu...   Jan 2 2016, 07:33 PM
mikesjunk   Ok for the fuel pressure regulator, if I just have...   Jan 3 2016, 10:57 AM
timothy_nd28   Yep, no need with a dual regulator setup. If the ...   Jan 3 2016, 11:01 AM
mikesjunk   I'm cheap so my shop is at 45F and I have good...   Jan 3 2016, 12:56 PM
timothy_nd28   K, does it stay running if you spray starting flui...   Jan 3 2016, 01:10 PM
mikesjunk   Well Tim you might be on to something there. So j...   Jan 3 2016, 03:17 PM
Jeff Bowlsby   Lots of different injectors - dependent on the ECU...   Jan 3 2016, 03:51 PM
timothy_nd28   The last test was to help isolate a fuel delivery ...   Jan 3 2016, 04:50 PM
mikesjunk   And the Frankenstein continues. The injector numb...   Jan 3 2016, 05:58 PM
timothy_nd28   Crazy stuff! :blink: Did you say that this ...   Jan 3 2016, 06:10 PM
mikesjunk   Someone on the other post said it looked like a 1....   Jan 3 2016, 06:39 PM
Al Meredith   I have owned 3 912Es and now have #265 But I conve...   Jan 3 2016, 07:35 PM
mepstein   I'm pulling a running '71 engine for a 6 c...   Jan 3 2016, 07:51 PM
timothy_nd28   I don't think they introduced cylinder head ve...   Jan 3 2016, 09:05 PM
mikesjunk   Yes Tim I'm on a similar page. I sent my sist...   Jan 3 2016, 09:54 PM
timothy_nd28   Yep, points are pretty easy and inexpensive. Anot...   Jan 3 2016, 10:19 PM
- Lo-Fi Version Time is now: 4th July 2025 - 12:47 PM
