SOlD 1974-1989 911 Front lower suspension with under body sway bar, Reastored with powder coated parts $400 |
bdstone914 |
Dec 30 2015, 10:51 PM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
SOLD
I have a 1974 and later 911 lower suspension with a 20mm under body sway bar. This is a good way to get a stiffer front end with 19mm torsion bars and a bolt on 20mm under body sway bar. All parts are powder coated satin black. Includes a set of seals for the torsion bars. $400. I can add installed Lemforder ball joints for $150 installed and rubber bushings for $50 installed. Parts List 2 911 A arms 1 steel cross member 2 front bearing brackets 2 rear bearing brackets 2 torsion bars 2 adjuster caps with adjuster screws 2 clamps for sway bar to cross member. 2 new torsion bar seals 2 torsion bar front covers All bolts, washers and lock washers for installation Sway bar bushing not included. Attached thumbnail(s) |
got914? |
Jan 4 2016, 07:21 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
Check your PM
Lo-Fi Version | Time is now: 4th June 2024 - 09:52 AM |
