| mb911 |
Dec 27 2015, 02:21 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,730 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
So while my 914-6 oil tanks are being machined I going to start working through my header with heat exhanger design out of stainless.. I do not have non compete on these with m&k so that gives me design freedom.. However I will use similar design process as the m&k/ rarlyl8 design. So my question is 1.5" the most common size or allot of you using 1.625
| jmill |
Dec 31 2015, 06:10 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
OK, I thought I had a couple of 2.0 muffler hangers I could give Ben. I don't. I must have gave them away or put them somewhere I wouldn't lose them. (IMG:style_emoticons/default/rolleyes.gif)
Ben needs some measurements. Can someone with a 2.0 muffler hanger give him the center to center measurements in the picture below. If a couple of guys pipe in and confirm them, even better. Attached image(s)
| Luke M |
Dec 31 2015, 06:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,497 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
OK, I thought I had a couple of 2.0 muffler hangers I could give Ben. I don't. I must have gave them away or put them somewhere I wouldn't lose them. (IMG:style_emoticons/default/rolleyes.gif) Ben needs some measurements. Can someone with a 2.0 muffler hanger give him the center to center measurements in the picture below. If a couple of guys pipe in and confirm them, even better. I have one off my 6. I'll go out and measure it in a few. 20" c to c on header flange mount, 5" c to c on trans mount holes, 6 1/4" c to c from trans mount down to center flange line. |
| mb911 |
Jan 4 2016, 03:34 PM
OK, I thought I had a couple of 2.0 muffler hangers I could give Ben. I don't. I must have gave them away or put them somewhere I wouldn't lose them. (IMG:style_emoticons/default/rolleyes.gif) Ben needs some measurements. Can someone with a 2.0 muffler hanger give him the center to center measurements in the picture below. If a couple of guys pipe in and confirm them, even better. I have one off my 6. I'll go out and measure it in a few. 20" c to c on header flange mount, 5" c to c on trans mount holes, 6 1/4" c to c from trans mount down to center flange line. Thanks for the info. I will mod my mount and start mocking up parts.. I have to make a hard decision on these.. I really wanted to use a burns style collector as they are so nice but that could drive the price up another 450 in cost over just a simple collector like you see so often. I looked at headers by eds website as they offer a bunch of options but I can buy everything locally for about the same price and I can locally source all the flanges as well.. So to meet my target of 1500. It looks like it will be the simplier collector.. What is everyone's thoughts on this? |
| jd74914 |
Jan 4 2016, 09:21 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,875 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Thanks for the info. I will mod my mount and start mocking up parts.. I have to make a hard decision on these.. I really wanted to use a burns style collector as they are so nice but that could drive the price up another 450 in cost over just a simple collector like you see so often. I looked at headers by eds website as they offer a bunch of options but I can buy everything locally for about the same price and I can locally source all the flanges as well.. So to meet my target of 1500. It looks like it will be the simplier collector.. What is everyone's thoughts on this? By simpler collector do you mean a formed collector vs. the nice welded ones with inner guide that Burns sells? |
| mb911 |
Jan 5 2016, 06:11 AM
Thanks for the info. I will mod my mount and start mocking up parts.. I have to make a hard decision on these.. I really wanted to use a burns style collector as they are so nice but that could drive the price up another 450 in cost over just a simple collector like you see so often. I looked at headers by eds website as they offer a bunch of options but I can buy everything locally for about the same price and I can locally source all the flanges as well.. So to meet my target of 1500. It looks like it will be the simplier collector.. What is everyone's thoughts on this? By simpler collector do you mean a formed collector vs. the nice welded ones with inner guide that Burns sells? Yes and no.. It would still be a welded assembly but much more like a formed collector.. |
mb911 Header sizing 914-6 Dec 27 2015, 02:21 PM
Steve Most common aftermarket is 1 5/8" OD for 3.2 ... Dec 27 2015, 02:29 PM
mepstein I would like 1 5/8 for my 3.2. I want your first s... Dec 27 2015, 03:38 PM
Dion I'll be in for a set. Would be for a 2.4L Ri... Dec 27 2015, 03:48 PM
wndsnd If these have heat, I would like to see what they ... Dec 27 2015, 05:25 PM
jmill From Dempsey's book
2.0-2.4 = 1 1/2 or 1 5/8
... Dec 27 2015, 07:30 PM
mb911
From Dempsey's book
2.0-2.4 = 1 1/2 or 1 5/8... Dec 28 2015, 05:49 AM
Mark Henry 1-1/2" up to 2.7
1-5/8" or 1 3/4" f... Dec 28 2015, 08:27 AM
JmuRiz My 2.7 was spec'd out at 1 5/8 by MSDS.
I... Dec 28 2015, 08:28 AM
Steve
I... Dec 28 2015, 10:30 AM
jmill
I need to come pick up that engine shortly
Com... Dec 28 2015, 08:50 AM
wndsnd Is there an accepted ratio between exhaust port si... Dec 28 2015, 05:27 PM
jmill
Is there an accepted ratio between exhaust port s... Dec 28 2015, 05:57 PM
mb911
Is there an accepted ratio between exhaust port ... Dec 28 2015, 06:25 PM
[quote name='jmill' post='2282534' date='Dec 28 2... Dec 28 2015, 07:19 PM
mb911
[quote name='jmill' post='2282534' date='Dec 28 ... Dec 28 2015, 07:39 PM
JmuRiz
Good point.. Well guess I will have to solve that... Dec 30 2015, 09:10 AM
jmill
Smaller engines already have the stock he's. ... Dec 28 2015, 09:45 PM
eitnurg Many (too many) years ago I had a Euro 3.2 and sta... Dec 29 2015, 03:40 AM
Mark Henry One thing I haven't seen discussed is the othe... Dec 29 2015, 06:32 AM
wndsnd Good information, those heads have 40mm exhaust va... Dec 29 2015, 11:13 AM
mepstein These. Open pipe. No baffle. No exhaust. Turn the ... Dec 29 2015, 12:02 PM
mb911 After the headers with heat are done. I will be wo... Dec 29 2015, 12:17 PM
Steve Any idea what the cost will be for 1 5/8" hea... Dec 29 2015, 12:40 PM
mb911
Any idea what the cost will be for 1 5/8" he... Dec 29 2015, 02:54 PM
Mark Henry
Any idea what the cost will be for 1 5/8" h... Dec 29 2015, 03:56 PM
brant I can't wait to see them and the cost also
I... Dec 29 2015, 01:24 PM
Travis Neff nice price! Dec 29 2015, 04:55 PM
mb911
nice price!
I hope I can make it happen th... Dec 29 2015, 05:05 PM
wndsnd Sounding good.
Would a rounder style heater box l... Dec 29 2015, 05:04 PM
mb911
Sounding good.
Would a rounder style heater box ... Dec 29 2015, 05:07 PM
wndsnd Got it. Dec 29 2015, 05:13 PM
mb911 Any feed back on the 914-6 vs 4cyl muffler bracket... Dec 29 2015, 06:23 PM
Travis Neff 914-6 headers and OE heat exchangers can use the 2... Dec 29 2015, 06:26 PM
mepstein Make up something cool from ss. I have an England ... Dec 29 2015, 06:41 PM
Travis Neff and by 2.0, I mean the 4 cyl 2.0 bracket Dec 29 2015, 07:17 PM
Travis Neff If you wanted to do something cool, one that would... Dec 29 2015, 07:18 PM
Steve I'm running factory six heat exchangers, with ... Dec 29 2015, 07:24 PM
mepstein England hanger Dec 30 2015, 09:15 AM
Mueller
England hanger
I'd ditch the welded-on stif... Dec 30 2015, 09:23 AM
mb911 Looks like I have c.. So the question is the heigh... Dec 30 2015, 12:45 PM
gandalf_025 Any chance you can make some simple ones like thes... Dec 30 2015, 02:51 PM
mb911
Any chance you can make some simple ones like the... Dec 30 2015, 03:50 PM
Gary
Any chance you can make some simple ones like the... Dec 31 2015, 12:03 PM
mb911 Who made this originally? Dec 30 2015, 03:50 PM
gandalf_025
Not entirely sure who... Dec 30 2015, 04:33 PM
wndsnd
[quote name='mb911' post='2283324' date='Dec 30 2... Dec 30 2015, 04:59 PM
mb911
[quote name='mb911' post='2283324' date='Dec 30 ... Dec 30 2015, 05:23 PM
mb911
[quote name='mb911' post='2283324' date='Dec 30 2... Dec 30 2015, 05:24 PM
jmill
Looks like I have c.. So the question is the heig... Dec 30 2015, 04:49 PM
jmill
England hanger
I'd ditch the welded-on sti... Dec 30 2015, 04:55 PM
mb911 Picked up the engine today thanks John. Going to b... Dec 31 2015, 02:40 PM
JmuRiz They aren't the same, the heights are differen... Dec 31 2015, 02:52 PM
mb911
They aren't the same, the heights are differe... Dec 31 2015, 03:00 PM
Luke M You would need a 914-6/914 2.0 bracket . There... Dec 31 2015, 05:25 PM
jd74914
By simpler collector do you mean a formed collec... Jan 5 2016, 01:42 PM
mb911
[quote name='mb911' post='2285682' date='Jan 5 20... Jan 5 2016, 03:32 PM
jd74914
I think I know what you're talking about bu... Jan 6 2016, 12:32 PM
396
[quote name='mb911' post='2285682' date='Jan 5 2... Mar 14 2016, 07:13 PM
wndsnd Design and build the best performance and quality ... Jan 4 2016, 04:47 PM
Eric_Shea It began to rain in Baton Rouge and it continued t... Jan 4 2016, 06:38 PM
porschetub
It began to rain in Baton Rouge and it continued ... Jan 5 2016, 03:14 AM
Cairo94507 I would love a set of SS headers for my 3.2 with h... Jan 4 2016, 11:13 PM
JmuRiz FYI I was looking at Armondo's 914/6 GT site a... Jan 5 2016, 01:19 PM
Justinp71 Another option to heat exchangers is seat warmers.... Jan 5 2016, 02:50 PM
Another option to heat exchangers is seat warmers... Jan 5 2016, 06:22 PM
wndsnd Updates? Jan 10 2016, 01:31 PM
mb911
Updates?
Sorry been finishing the oil tanks up... Jan 10 2016, 01:36 PM
wndsnd Watching both keenly! :) Jan 10 2016, 02:15 PM
mb911 Well I have refined the oil tank process so I shou... Mar 14 2016, 01:46 PM
JmuRiz Sounds good to me, 6 weeks seems pretty quick to m... Mar 14 2016, 01:50 PM
mb911 So this project is going to start soon but I have ... Jul 8 2016, 10:39 AM
wndsnd I would consider that...
I am dreading late Fall.... Jul 8 2016, 11:00 AM
JmuRiz If they work with Marty's (MSDS) headers, I... Jul 8 2016, 01:31 PM
gereed75 I actually think the idea of a heat plenum that wo... Jul 8 2016, 02:13 PM
mb911
I actually think the idea of a heat plenum that w... Jul 8 2016, 02:32 PM
mb911 What I would need is a set to model off of. Anyone... Jul 8 2016, 02:32 PM
gereed75 I have an old set of what I think are Burschs that... Jul 8 2016, 02:58 PM
Perry Kiehl Clone I tried to get factory 6 HE's reproduced about... Jul 8 2016, 11:26 PM
mb911 Agreed I made hundreds of sets of headers for rarl... Jul 9 2016, 05:58 AM
Perry Kiehl Clone You can't make heat exchangers out of mild ste... Jul 9 2016, 07:53 AM
mb911 with the 911 market we made the heat exchangers ou... Jul 9 2016, 08:07 AM
mb911 Another thought I just had as I was looking at my ... Jul 9 2016, 12:36 PM
Another thought I just had as I was looking at my... Jul 9 2016, 01:39 PM
Perry Kiehl Clone
Another thought I just had as I was looking at my... Jul 9 2016, 04:51 PM
bahnzai Ben,
I have a factory set of 914-6 exhaust I will ... Jul 9 2016, 01:52 PM
mb911 Way better . This was a common upgrade for 3.2 car... Jul 9 2016, 07:49 PM
396
Way better . This was a common upgrade for 3.2 ca... Jul 10 2016, 12:19 AM
mb911 I do. Jul 10 2016, 05:18 AM
JmuRiz :D
Interesting about the 3.6 heat exchangers...Sc... Jul 10 2016, 06:43 PM
mb911 Quick update as I work one the Gt steel rocker fla... Aug 21 2016, 02:22 PM
Eric_Shea (2) Pair please. :D Aug 21 2016, 04:05 PM
restore2seater Any estimate on GB cost? Aug 21 2016, 06:08 PM
raynekat I'm interested in a set of 1-5/8" heat ex... Aug 22 2016, 12:36 AM
mb911 Target for group buy is 1500.. I will firm this up... Aug 22 2016, 05:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:18 PM |
