> Trailing arm reinforcements? And wheel studs
mb911
post Jan 9 2016, 09:34 AM
I am at the point where I will be sand blasting the suspension and doing the 5 lug conversion. Do the trailing arms flex that much that they need reinforcement for a street car? And what length wheel stud should I use for the 5 lug conversion?
Cracker
post Jan 9 2016, 02:24 PM
It is my opinion that it would be unnecessary to reinforce the trailing arms for a street car/hot rod. The stock stud length works fine for Fuchs so long as you're not using a spacer longer than 5/8" - all the best!
Tony
tomrev
post Jan 9 2016, 02:40 PM
I think the better option is to drill the holes to insert some 1 in. OD steel tube, going diagonally thru the trailing arm, and weld where they go thru. Sort of internal trussing, two per arm, on opposing angles. A search will bring up photos. Much less weight, weld embrittlement, and a stronger finished product.
mb911   Trailing arm reinforcements? And wheel studs   Jan 9 2016, 09:34 AM
sled9146   Good questions, answers are based on your driving ...   Jan 9 2016, 11:35 AM
Bruce Hinds   Not sure about the trailing arm question, I purcha...   Jan 9 2016, 11:48 AM
mb911   Not sure about the trailing arm question, I purch...   Jan 9 2016, 11:52 AM
campbellcj   To box or not to box. That's an age-old questi...   Jan 9 2016, 01:16 PM
Mark Henry   This area it's more an issue with the body mou...   Jan 9 2016, 01:23 PM
Bruce Hinds   This area it's more an issue with the body mo...   Jan 9 2016, 02:01 PM
Cracker   It is my opinion that it would be unnecessary to r...   Jan 9 2016, 02:24 PM
tomrev   I think the better option is to drill the holes to...   Jan 9 2016, 02:40 PM
Travis Neff   the stock 45mm studs should be fine, unless you wa...   Jan 9 2016, 03:11 PM
mgp4591   the stock 45mm studs should be fine, unless you w...   Jan 9 2016, 03:53 PM
JRust   And when Jamie bent his arm up over a year ago, h...   Jan 9 2016, 03:58 PM
mgp4591   And when Jamie bent his arm up over a year ago, ...   Jan 9 2016, 04:07 PM
screenguy914   What came first, a distorted control arm that lead...   Jan 9 2016, 05:51 PM
Cracker   ...the question regarding strengthening the traili...   Jan 9 2016, 06:01 PM
shoguneagle   There use to be a lot of information concerning th...   Jan 9 2016, 09:50 PM
dug   A wise old IMSA racer said they stopped bending tr...   Nov 30 2016, 02:03 AM
mbseto   I think the better option is to drill the holes t...   Nov 30 2016, 12:13 PM
Steve   Track car I would box it. Street car I would not....   Nov 30 2016, 12:29 PM
mb911   Not sure how this got revisited but decided to lea...   Nov 30 2016, 01:45 PM
6freak   I am at the point where I will be sand blasting t...   Nov 30 2016, 03:59 PM
wndsrfr   My .02c is while you have it down to clean metal, ...   Nov 30 2016, 04:47 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 04:10 PM
