> Subaru engine, Which one
r_towle
post Jan 11 2016, 05:55 PM
Custom Member
Not trying to be a dick, but please (pretty please) answer just my specific question because I am old, I don't understand all these numbers, and I want to start shopping.
What is the biggest, most horsepower, turbo, gas, Subaru engine that easily ( no drive by wire or anti theft stuff) can be swapped into the car?
matthepcat
post Jan 11 2016, 11:17 PM
Meat Popsicle
The great thing about a turbo EJ motor is the great aftermarket support. Hundreds of companies making parts to support these family of motors and if the urge for more power is there, it is cheap to buy a tune and turn up the boost. I don't really understand the argument for simplicity, as the turbo does not really add much complexity. You still have to fab a custom exhaust on both motors. You just have to relocate the air to air inter cooler to fit, or run a water to air.
r_towle
post Jan 12 2016, 08:34 AM
Custom Member
QUOTE(matthepcat @ Jan 12 2016, 12:17 AM) *
This project needs a turbo, and needs to be in the right family of engines so I can boost the power if required over time.
Simplicity for me is to know what motor to buy, a turbo, a 4 cylinder.
As all of these threads go, there are so many opinions that do not answer the initial question, thus why I get confused with all the numbers and give up again....
Six cylinder motor is not an option.
Using a stock ECU would be my first choice to keep the up front costs down initially, but have that option later on.
Rich
DBCooper
post Jan 12 2016, 09:17 AM
14's in the 13's with ATTITUDE
QUOTE(r_towle @ Jan 12 2016, 06:34 AM) *
Rich
OK, real simple, buy an STi motor, U.S. market, any year but the newer the better. You're going to find that those are a bit expensive so the next option would be a U.S. market WRX motor, again as new as possible, about half the price and not much of a step down from the STi.
That's the answer to your question, but I don't think you're asking the right question. The problem will be the drive-by-wire, variable valve timing, immobilizer, etc. If you use late model versions of either of those engines with a stock ECU you'll need to incorporate so much of the donor car's systems into the swap to satisfy what the OEM ECU needs to run that your project won't be simple any more. And those lower "initial" costs will turn into a lot more time, work and expense. I don't want to TELL you what to do, but I'd suggest you consider using an aftermarket ECU, even if only a Megasquirt, to keep the whole thing simpler, and in the end cheaper. And that's going to be simpler/cheaper even after paying someone for a nice dyno-tune at the end.
The next alternative is Matt's suggestion, an older 2003-2005 WRX EJ205 engine that may not be the pinnacle of the monster power map, but is a straightforward engine with 230 stock horsepower that's simple, proven, and well supported by the aftermarket so can be easily modified when you want. It's what I have, and I'm pretty sure it would have more enough power to keep you entertained for a long time. A long long time, you being so old and all ( (IMG:style_emoticons/default/poke.gif) ). The nice thing about the EJ motors is that they aren't too expensive or hard to find, so once the work to finish the basic conversion part is done you can plug-and-play with lots of different variations if you happen to blow one up, want more power, do some experimentation with E85, stupid big turbos, or whatever.
r_towle   Subaru engine   Jan 11 2016, 05:55 PM
DBCooper   Biggest and baddest? That would be the STi 2.5 li...   Jan 11 2016, 06:34 PM
matthepcat   https://en.wikipedia.org/wiki/Subaru_EJ_engine EJ...   Jan 11 2016, 06:47 PM
r_towle   There is just nothing,simple about this . EJ207 w...   Jan 11 2016, 08:22 PM
JRust   Simple would be go with the ez30 & aftermarket...   Jan 11 2016, 08:33 PM
r_towle   Thanx   Jan 11 2016, 08:37 PM
76-914   IIRC, they're up to 330hp on the STI now. I...   Jan 11 2016, 08:52 PM
Mwood   dont know much about the EZ but the EG33 from an s...   Jan 11 2016, 08:54 PM
DBCooper   ez30 also has a weird head with only one exhaust ...   Jan 11 2016, 10:04 PM
DBCooper   Oops, dopple post. Don't know how that happen...   Jan 11 2016, 10:13 PM
flmont   the Tribeca subie engine(2005-2009) or EX30D 3.6 m...   Jan 11 2016, 09:23 PM
flmont   any engine can have nice ratings but over time Iam...   Jan 11 2016, 09:25 PM
ThePaintedMan   Having just torn down my EG33, I must say it's...   Jan 11 2016, 09:55 PM
Chris H.   Yes, 2003-2009 had three exhaust ports per side, v...   Jan 11 2016, 10:32 PM
Mwood   Here's a pic of the ez30 (3.0L) head ez30 The...   Jan 11 2016, 10:35 PM
matthepcat   The great thing about a turbo EJ motor is the grea...   Jan 11 2016, 11:17 PM
r_towle   The great thing about a turbo EJ motor is the gre...   Jan 12 2016, 08:34 AM
DBCooper   This project needs a turbo, and needs to be in th...   Jan 12 2016, 09:17 AM
matthepcat   :agree: The WRX motor 2006+ is even the same dis...   Jan 12 2016, 10:08 AM
DBCooper   It's not 100% necessary, but at big turbo/hi...   Jan 12 2016, 10:43 AM
partwerks   :agree: The WRX motor 2006+ is even the same di...   Aug 13 2022, 09:58 PM
r_towle   When did the WRX STI motor start? Thought it was 3...   Jan 12 2016, 07:51 PM
matthepcat   The Subaru STI started in 1999 in Japan but didn...   Jan 12 2016, 11:39 PM
cwpeden   Don't want to hijack but... If one was to comp...   Jan 12 2016, 08:39 PM
Chris H.   Don't want to hijack but... If one was to com...   Jan 12 2016, 10:06 PM
tazz9924   2.0, not sure if they were twin scroll or not, i d...   Aug 14 2022, 09:45 AM
914GTSTI   I have run a 1996 JDM V2 STI in a Forster and it w...   Aug 14 2022, 02:58 PM
Justinp71   If you want simple run the stock computer, OEM Har...   Aug 14 2022, 11:22 PM
- Lo-Fi Version Time is now: 12th July 2025 - 04:39 PM
