> Oil Galley Plugs, Just replace the five big ones?
saigon71
post Jan 18 2016, 01:49 PM
In preparation for an engine rebuild, I wanted to get myself up to speed on drilling/tapping the oil galley plugs.
Search revealed conflicting information about whether all should be removed and tapped or just the five big ones.
What's the current school of thought on this?
Also, what size plugs and drill/tap will I need.
Thanks!
http://www.914world.com/bbs2/index.php?sho...=103988&hl=
Mark Henry
post Jan 19 2016, 08:15 AM
that's what I do!
3/8" NPT pipe tap, 9/16 drill bit use steel plugs.
Go slow, for a bare case I use WD-40 for lube. Keep the tap square, remove and clean the tap often when cutting.
When you tap check to make sure the plug goes in deep enough, but not too deep, you want it just a bit proud.
Clean well, I pressure wash the case.
Then use loctite to set the plugs, Never use teflon tape on a NPT plug or fitting, especially in aluminum.
Some will say you should use brass or aluminum plugs because they have the same expansion rates. IMHO in this case it's horse shit, I've never once seen a steel plug leak, but I have seen brass or aluminum plugs strip the hex out.
r_towle
post Jan 19 2016, 08:29 AM
Custom Member
QUOTE(Mark Henry @ Jan 19 2016, 09:15 AM) *
Where did you order the allen head plugs?
Mark Henry
post Jan 19 2016, 09:02 AM
that's what I do!
QUOTE(r_towle @ Jan 19 2016, 09:29 AM) *
Pretty common plug, any plumbing supply definetly should have them on the shelf. Most Hydraulic and hardware supply stores should have them as well.
Here I can get them at Home Debit and Low's.
I bought a bunch of 1/8"NPT plugs for my /6 engine cam towers at Fastenal.
Personally I have a hardware guy who comes by with a panel truck every 4-6 weeks, I bought them right off the truck.
Mine are Paulin/papco brand.
saigon71   Oil Galley Plugs   Jan 18 2016, 01:49 PM
Porschef   Bob, I did mine as a precaution before installing ...   Jan 18 2016, 05:52 PM
Mark Henry   3/8" NPT pipe tap, 9/16 drill bit use steel p...   Jan 19 2016, 08:15 AM
r_towle   3/8" NPT pipe tap, 9/16 drill bit use steel ...   Jan 19 2016, 08:29 AM
Mark Henry   Where did you order the allen head plugs? Prett...   Jan 19 2016, 09:02 AM
Dave_Darling   IIRC, there is one plug that will block an importa...   Jan 19 2016, 10:33 AM
Mark Henry   IIRC, there is one plug that will block an import...   Jan 19 2016, 11:33 AM
McMark   McMaster has them.   Jan 19 2016, 10:36 AM
rhcb914   I bought a box of 100 steel hex hed plugs from Gra...   Jan 19 2016, 08:06 PM
Jake Raby   I'm building a 2270 for a World member now.. L...   Jan 19 2016, 09:57 PM
saigon71   Thanks for the responses and recommendations. :b...   Feb 2 2016, 08:29 PM
rdauenhauer   are those steel or Alum. plugs?   Feb 2 2016, 10:10 PM
saigon71   are those steel or Alum. plugs? Steel.   Feb 3 2016, 08:10 AM
Olympic 1.7   When I did mine I got an extra tap and ground the ...   Feb 3 2016, 08:30 AM
McMark   :agree: A second tap is handy. Also, when drillin...   Feb 3 2016, 08:35 AM
Mark Henry   :agree: A second tap is handy. Also, when drilli...   Feb 3 2016, 10:20 AM
McMark   Oh yeah. That for sure! :agree:   Feb 3 2016, 12:58 PM
nathansnathan   When I did this the 1st time, I had got some 3/8...   Feb 3 2016, 05:14 PM
Mark Henry   When I did this the 1st time, I had got some 3/8...   Feb 3 2016, 08:38 PM
nathansnathan   When I did this the 1st time, I had got some 3/8...   Feb 4 2016, 12:03 AM
Mark Henry   [quote name='Mark Henry' post='2298151' date='Feb...   Feb 4 2016, 07:38 AM
McMark   Wd-40 is better than goo-gone for removing stick r...   Feb 3 2016, 09:50 PM
nine9three   I've always used JB Weld to seal mine. Never...   Feb 4 2016, 12:11 AM
Puebloswatcop   WD40 does a fair job, but if you want really clean...   Feb 4 2016, 08:31 AM
McMark   I love how these threads go awry. :lol: Is cuttin...   Feb 4 2016, 09:04 AM
914_teener   I love how these threads go awry. :lol: Is cutti...   Feb 4 2016, 09:35 AM
pilothyer   You can spend the money on special for aluminum ...   Feb 4 2016, 09:20 AM
Mark Henry   You can spend the money on special for aluminum ...   Feb 4 2016, 10:59 AM
McMark   Had to. This got way too dramatic over WD-40. :r...   Feb 4 2016, 09:40 AM
Mark Henry   Had to. This got way too dramatic over WD-40. :...   Feb 4 2016, 10:20 AM
Mark Henry   Now I have it pretty well flush, BTW I'll be d...   Feb 4 2016, 10:23 AM
Mark Henry   This came out good :) This show the one plug you ...   Feb 4 2016, 10:31 AM
Mark Henry   The last pic shows 3 different steel plugs. The on...   Feb 4 2016, 10:43 AM
saigon71   Thanks for all the technical support on this...esp...   Mar 13 2016, 05:13 PM
Mark Henry   :thumbsup: Good job!   Mar 13 2016, 08:42 PM
- Lo-Fi Version Time is now: 8th September 2026 - 07:44 AM
