914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I'm installing a pump for the washer fluid instead of using the spare tire. I can extend the black/brown wire to the pump. Can someone confirm which wire that is?
I'd like to hook the pump up to the wiper stalk and not have to run a separate switch. I've read it can be hooked up so the intermittent wipers will run it. I have a '72; do I have intermittent wipers? I could not find any reference to them in the owner's manual, so I'm guessing I don't. I've included a picture of the wiper/turn signal assembly for reference. How do I tap into the wire on my existing stalk? I've read I can get a 911/924 wiper assembly and it will work. Is this true and will it fit my car? How does that option work? Attached image(s) ![]() |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
Non of the wires.
There is no switch for the pump in there. You need a different switch that has an extra wire OUTSIDE the connector. |
Lo-Fi Version | Time is now: 15th July 2025 - 04:01 AM |
