How to install new plastic brake ressovor lines ., What is the best way ? |
72914wrx |
Jan 24 2016, 07:23 PM
Member Group: Members Posts: 86 Joined: 5-January 15 From: Fresno Member No.: 18,298 Region Association: None |
I was trying to install new plastic ressovor lines and can't get them all the way down on the steel feeder tube . I tried some light oil with no luck . What is the best way? I've done the old stove trick . Using PBM new lines .
Attached thumbnail(s) |
72914wrx |
Jan 24 2016, 10:21 PM
I'll let you know how this goes ! Looks like a sence from braking Bad .
porschetub |
Jan 25 2016, 12:23 AM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I'll let you know how this goes ! Looks like a sence from braking Bad . I have the same issue putting the ferrals in my replacement plastic fuel line,a quick wave over with a heat gun is the trick,they will never come off except with a cutter. I found boiling water not quite enough. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:05 AM |
