914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I'm installing a pump for the washer fluid instead of using the spare tire. I can extend the black/brown wire to the pump. Can someone confirm which wire that is?
I'd like to hook the pump up to the wiper stalk and not have to run a separate switch. I've read it can be hooked up so the intermittent wipers will run it. I have a '72; do I have intermittent wipers? I could not find any reference to them in the owner's manual, so I'm guessing I don't. I've included a picture of the wiper/turn signal assembly for reference. How do I tap into the wire on my existing stalk? I've read I can get a 911/924 wiper assembly and it will work. Is this true and will it fit my car? How does that option work? Attached image(s) ![]() |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
Yes it fits and looks the exactly the same. I installed one in my car.
This is the one I used: http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G It's OK quality but the movement is a bit rough compared to the SWF. If money is not an issue, I would take the offer from Mark. Else, get the $30 reproduction.. P.S. I had a thread with pictures about installing the switch. You just need to run one wire to the pump. |
Lo-Fi Version | Time is now: 15th July 2025 - 03:45 AM |
