> Thermostat Questions
orbit398
post Jan 25 2016, 10:39 AM
Putting my engine back together and have a few questions on the thermostat. I did the check to make sure it grows to the proper length (1.81" at 150 -160 degree water) and it seems close enough. Air flappers all operate fine, accept I think there is a little interference with the drivers side flap. If I try to close the flap all the way, it appears to hit a small piece on the aluminum large air bracket. See pics. I can't shift that flapper door down the bar a bit allowing it to clear this small piece of aluminum sticking out. I can modify the flapper a bit so it'd close all the way but figured I'd ask folks.
Next Question, are there instructions on how to adjust the cable operation of the air flappers. I assume I need to pull the thermostat to it's extended length and secure the small cable to the flapper bar location at that cable length. The result being that when the thermostat is extended, the cable should allow the flapper bar spring to fully open the air flappers.
thanks for any advice
914ltd
post Jan 30 2016, 08:26 AM
As for the workshop manual, it gives only the heated dimension of the thermostat. With that information, all thermostats are OK! We had a 914 with a freshly rebuilt engine arrive here in summer from Chicago (150 miles) for overheating questions. The flaps were set with a bad thermostat. I installed a used thermo and changed oil, OK so far.
I am almost out of good used thermostats, I'm sure this has been addressed but is there a (reliable) source? Thanks, Brad
- Lo-Fi Version Time is now: 2nd April 2026 - 11:49 AM
