| 7TPorsh |
Jan 20 2016, 01:45 PM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
I had a hell of a time getting the header in with this shift rod in place. I have an exhaust leak on #1 and want to fix it easily. Rather than fuss with limited clearance and space, I want to remove the shift rod so I can just unbolt all four ports and re-install in one piece rather than one tube at a time.
How can I remove the rod; hopefully with simple tools. |
| rhodyguy |
Jan 31 2016, 06:46 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The pivot ball stem unscrews from the firewall. Like joe said. Replace the rear carrier bushing and examine the pivot ball on the stem. If you uncouple any of the rods index your current settings with a fine tip sharpie at the connection points. Look at the linkage illustrations in your Haynes.
7TPorsh How Do You Remove An Early Shift Rod Jan 20 2016, 01:45 PM
Series9
I had a hell of a time getting the header in with... Jan 20 2016, 03:49 PM
stugray
I had a hell of a time getting the header in wit... Jan 20 2016, 06:13 PM
7TPorsh Thanks guys, going to try it this weekend! Jan 21 2016, 11:12 AM
7TPorsh Is there any bushing or sleeve/washer that I shoul... Jan 21 2016, 04:50 PM
7TPorsh Is there any bushing or sleeve/washer that I shoul... Jan 21 2016, 04:51 PM
7TPorsh I've got the rear linkage undone so the rod is... Jan 31 2016, 05:06 PM
7TPorsh So do i unscrew the entire rod?
Still confused. H... Jan 31 2016, 07:29 PM
rhodyguy #51 IS the stem. The stem is threaded on the firew... Jan 31 2016, 09:03 PM
7TPorsh Managed to get the rod off and the header out. Gat... Feb 16 2016, 11:59 AM
stugray
Managed to get the rod off and the header out. Ga... Feb 16 2016, 01:11 PM
7TPorsh
Managed to get the rod off and the header out. G... Feb 16 2016, 05:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 07:36 AM |
