Vent hose routing question |
rosenfe |
Jan 31 2016, 10:25 AM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
On my 73 2.0 with carbs.so I have gas tank vent going to head that's ok but what do I do with hoses coming from left and right head? Should I join both and put into port at oil filler housing?
rhodyguy |
Jan 31 2016, 09:58 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
That style of BB is not a sealed unit. There are little stand offs on the top. There is a foam filter inside that helps trap the oil vapors, the puddle of oils forms on the bottom, and runs out of the 2 side ports. The foam trap should squeezed occasionally to rid it of oil. You can also plumb the 2 side ports to the head vents as they are open to the valve train area and let gravity do the work.
Lo-Fi Version | Time is now: 10th June 2024 - 10:17 PM |
