Vent hose routing question |
rosenfe |
Jan 31 2016, 10:25 AM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
On my 73 2.0 with carbs.so I have gas tank vent going to head that's ok but what do I do with hoses coming from left and right head? Should I join both and put into port at oil filler housing?
rosenfe |
Jan 31 2016, 07:13 PM
so you are saying to insert gas vent to air filter on carbs,my filters are tiny and have no provision for inlet hose.
SirAndy |
Jan 31 2016, 07:26 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
so you are saying to insert gas vent to air filter on carbs,my filters are tiny and have no provision for inlet hose. None of the after market carbs are setup for the tank breather. You'll have to make your own connectors. (IMG:style_emoticons/default/smile.gif) |
michael7810 |
Jan 31 2016, 09:02 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
so you are saying to insert gas vent to air filter on carbs,my filters are tiny and have no provision for inlet hose. None of the after market carbs are setup for the tank breather. You'll have to make your own connectors. (IMG:style_emoticons/default/smile.gif) Here's my vent system on a 72 1.7L with carbs. |
Mark Henry |
Feb 1 2016, 04:55 PM
so you are saying to insert gas vent to air filter on carbs,my filters are tiny and have no provision for inlet hose. None of the after market carbs are setup for the tank breather. You'll have to make your own connectors. (IMG:style_emoticons/default/smile.gif) Here's my vent system on a 72 1.7L with carbs. That's close but still wrong. The blow through for the C. canister should be a separate hose to the air filter. Fuel venting and crankcase venting should never meet. |
SirAndy |
Feb 1 2016, 05:19 PM
The blow through for the C. canister should be a separate hose to the air filter. Fuel venting and crankcase venting should never meet. (IMG:style_emoticons/default/agree.gif) |
michael7810 |
Feb 2 2016, 01:30 PM
The blow through for the C. canister should be a separate hose to the air filter. Fuel venting and crankcase venting should never meet. (IMG:style_emoticons/default/agree.gif) Thanks - I'll work on that next time I'm in there. If I move all crankcase vent to 1 carb and fuel vent to the other; will that be OK? |
Lo-Fi Version | Time is now: 11th June 2024 - 11:18 AM |
