| Bulldog9 |
Feb 2 2016, 10:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 706 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Lets talk Octane..... What is the consensus on grade of fuel? I'm running 96 x 71 bore & stroke with .060" deck height 58.8cc chambers in the heads, and flat top pistons with no valve reliefs, and figure my CR is around 8.6:1. I'm thinking I can run regular, but no idea.
I've been running Chevron 92 so far, but dont want to wast $ and leave unburnt fuel residue. The higher the octane, the more resistant the fuel is to combustion, so unnecessary use of 'hitest' is dirtier combustion wise than regular. I haven't done any experimenting yet, but wanted to get some experience before I do. I plan to run the current tank down to close to empty, then put in 5 gallons of regular and see how that goes, but just wondering. |
| 80cap |
Feb 2 2016, 05:27 PM
Member ![]() ![]() Group: Members Posts: 322 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
I think the better thing to consider is that ethanol fuel sucks. I am lucky that a gas station near to me sells straight 92 octane gas. I use it in all my lawn equipment and two stroke motors. The gas doesn't go bad in 30 days and destroy all the carbs and fuel lines. The extra cost is worth it in no repairs.
Brian |
Steve Pratel Octane Feb 2 2016, 10:33 AM
Mikey914 With that compression you should be able to run re... Feb 2 2016, 10:59 AM
stugray Altitude also matters.
The higher the alt. the low... Feb 2 2016, 11:24 AM
Tom_T Steve -
My 88 Westy WBX-4 with Digifont is a deve... Feb 2 2016, 03:52 PM
Steve Pratel Great, thanks guys. Now I just need to find the ... Feb 2 2016, 05:05 PM
Ansbacher My '74 2.0 L with dual Dellorto carbs loves 90... Feb 2 2016, 05:48 PM
914_teener
Lets talk Octane..... What is the consensus on gr... Feb 2 2016, 06:41 PM
Steve Pratel
Lets talk Octane..... What is the consensus on g... Feb 2 2016, 07:24 PM
jim_hoyland Speaking of Ethanol; manufactures of AFR gauges an... Feb 2 2016, 06:51 PM
Mark Henry Anything above stock CR you likely should move up ... Feb 2 2016, 08:03 PM
carr914 E-Free! :headbanger:
http://www.pure-gas.or... Feb 2 2016, 07:25 PM
Steve Pratel
http://www.pure-gas.o... Feb 2 2016, 07:29 PM
somd914 Ethanol-free... Only a dream here in Maryland. O... Feb 2 2016, 08:39 PM
gfg3
Ethanol-free... Only a dream here in Maryland. ... Feb 3 2016, 04:23 PM
Mark Henry The one thing I've wondered about is if you re... Feb 2 2016, 09:00 PM
914_teener
The one thing I've wondered about is if you r... Feb 3 2016, 12:11 AM
Mark Henry
The one thing I've wondered about is if you ... Feb 3 2016, 10:25 AM
Madswede
[quote name='Mark Henry' post='2297644' date='Feb... Feb 3 2016, 11:53 PM
914_teener
[quote name='Mark Henry' post='2297644' date='Fe... Feb 4 2016, 09:44 AM
Dave_Darling If you're running a stock mild, mild, mild cam... Feb 2 2016, 10:12 PM
r_towle I run cheap gas in everything I own.
Audi, 914s, 9... Feb 2 2016, 10:20 PM
bretth Is it usually only the 91 octane that comes as eth... Feb 4 2016, 08:00 AM
Philip W.
Is it usually only the 91 octane that comes as et... Feb 4 2016, 11:17 AM
GregAmy I'm no chemist (and I don't play one on TV... Feb 4 2016, 10:54 AM
Mark Henry
You're far better off finding a local suppli... Feb 4 2016, 12:02 PM
Madswede
I'm no chemist (and I don't play one on T... Feb 4 2016, 10:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:45 AM |
