> Octane
Bulldog9
post Feb 2 2016, 10:33 AM
Lets talk Octane..... What is the consensus on grade of fuel? I'm running 96 x 71 bore & stroke with .060" deck height 58.8cc chambers in the heads, and flat top pistons with no valve reliefs, and figure my CR is around 8.6:1. I'm thinking I can run regular, but no idea.
I've been running Chevron 92 so far, but dont want to wast $ and leave unburnt fuel residue. The higher the octane, the more resistant the fuel is to combustion, so unnecessary use of 'hitest' is dirtier combustion wise than regular.
I haven't done any experimenting yet, but wanted to get some experience before I do. I plan to run the current tank down to close to empty, then put in 5 gallons of regular and see how that goes, but just wondering.
914_teener
post Feb 2 2016, 06:41 PM
QUOTE(Steve Pratel @ Feb 2 2016, 08:33 AM) *
Octane is a rating referring to the tendency to detonate. So the rating refers to a ratio of mix of octane and heptane. That is the standard. Octane and heptane are two different carbon chain molecules fuels. Buying a higher rated octane fuel doesn't mean it is a dirtier fuel.
I think when you posted combustion you meant detonation?
The propensity for detonation is caused by many factors but mostly by the combustion chamber and how the engine breathes and the fuel, so several things besides that octane rating.
Jake Raby has wrote untold threads on this.....he mostly says this in a few words as "its all in the combo" on how to create optimum power, not just in the CR ratio or the octane rating of the fuel.
Steve Pratel   Octane   Feb 2 2016, 10:33 AM
Mikey914   With that compression you should be able to run re...   Feb 2 2016, 10:59 AM
stugray   Altitude also matters. The higher the alt. the low...   Feb 2 2016, 11:24 AM
Tom_T   Steve - My 88 Westy WBX-4 with Digifont is a deve...   Feb 2 2016, 03:52 PM
Steve Pratel   Great, thanks guys. Now I just need to find the ...   Feb 2 2016, 05:05 PM
80cap   I think the better thing to consider is that ethan...   Feb 2 2016, 05:27 PM
Ansbacher   My '74 2.0 L with dual Dellorto carbs loves 90...   Feb 2 2016, 05:48 PM
914_teener   Lets talk Octane..... What is the consensus on gr...   Feb 2 2016, 06:41 PM
Steve Pratel   Lets talk Octane..... What is the consensus on g...   Feb 2 2016, 07:24 PM
jim_hoyland   Speaking of Ethanol; manufactures of AFR gauges an...   Feb 2 2016, 06:51 PM
Mark Henry   Anything above stock CR you likely should move up ...   Feb 2 2016, 08:03 PM
carr914   E-Free! :headbanger: http://www.pure-gas.or...   Feb 2 2016, 07:25 PM
Steve Pratel   E-Free! :headbanger: http://www.pure-gas.o...   Feb 2 2016, 07:29 PM
somd914   Ethanol-free... Only a dream here in Maryland. O...   Feb 2 2016, 08:39 PM
gfg3   Ethanol-free... Only a dream here in Maryland. ...   Feb 3 2016, 04:23 PM
Mark Henry   The one thing I've wondered about is if you re...   Feb 2 2016, 09:00 PM
914_teener   The one thing I've wondered about is if you r...   Feb 3 2016, 12:11 AM
Mark Henry   The one thing I've wondered about is if you ...   Feb 3 2016, 10:25 AM
Madswede   [quote name='Mark Henry' post='2297644' date='Feb...   Feb 3 2016, 11:53 PM
914_teener   [quote name='Mark Henry' post='2297644' date='Fe...   Feb 4 2016, 09:44 AM
Dave_Darling   If you're running a stock mild, mild, mild cam...   Feb 2 2016, 10:12 PM
r_towle   I run cheap gas in everything I own. Audi, 914s, 9...   Feb 2 2016, 10:20 PM
bretth   Is it usually only the 91 octane that comes as eth...   Feb 4 2016, 08:00 AM
Philip W.   Is it usually only the 91 octane that comes as et...   Feb 4 2016, 11:17 AM
GregAmy   I'm no chemist (and I don't play one on TV...   Feb 4 2016, 10:54 AM
Mark Henry   You're far better off finding a local suppli...   Feb 4 2016, 12:02 PM
Madswede   I'm no chemist (and I don't play one on T...   Feb 4 2016, 10:08 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:47 AM
