> Octane
Bulldog9
post Feb 2 2016, 10:33 AM
Lets talk Octane..... What is the consensus on grade of fuel? I'm running 96 x 71 bore & stroke with .060" deck height 58.8cc chambers in the heads, and flat top pistons with no valve reliefs, and figure my CR is around 8.6:1. I'm thinking I can run regular, but no idea.
I've been running Chevron 92 so far, but dont want to wast $ and leave unburnt fuel residue. The higher the octane, the more resistant the fuel is to combustion, so unnecessary use of 'hitest' is dirtier combustion wise than regular.
I haven't done any experimenting yet, but wanted to get some experience before I do. I plan to run the current tank down to close to empty, then put in 5 gallons of regular and see how that goes, but just wondering.
GregAmy
post Feb 4 2016, 10:54 AM
I'm no chemist (and I don't play one on TV) but...one of the tests I do as an SCCA scrutineer is to determine the amount of ethanol in the fuel (we allow 10% max).
The method I use is to take a sample of fuel from the car and pour it into a 100mL graduated cylinder to the 90mL mark. I then pour in 10mL of water. Shake it up briskly and then let it sit. The water will "capture" (whatever the correct word is) the ethanol from the gasoline and a clear line will emerge between the gasoline and the water/ethanol mix. The difference between the measurement of the mix and my original 10mL of water is how much alcohol was in the fuel; simple math (difference divided by 90) tells me what the percentage was.
If this is something you wanted to do yourself, you can, but it presents a couple problems to you:
One, the water/ethanol mix goes to the bottom, but how are you going to decant the gasoline off the top efficiently and at the production levels you're looking for? And what are you going to do with the resulting dregs (please don't pour it down the drain!)
Two, as noted above, ethanol increases octane (which is why SCCA limits max level). If you decant out all the ethanol, you have no way of knowing what the resulting octane of your gasoline is. And it's not a linear add/subtract ratio (i.e., you can't add 50/50 94 octane and 110 octane together and call it 102; it comes out to more like 98).
You're far better off finding a local supplier of non-ethanol fuel. Easier, cheaper, less mess and hassles.
GA
Mark Henry
post Feb 4 2016, 12:02 PM
that's what I do!
QUOTE(GregAmy @ Feb 4 2016, 11:54 AM) *
That's why I never tried it, in my area 91 premo is pure gas.
Thank's for the info Madswede, I just brought this up because there's a couple guy's doing this on youtube.
I know nothing on the chemistry end other than how to do the simple test for ethanol.
Steve Pratel   Octane   Feb 2 2016, 10:33 AM
Mikey914   With that compression you should be able to run re...   Feb 2 2016, 10:59 AM
stugray   Altitude also matters. The higher the alt. the low...   Feb 2 2016, 11:24 AM
Tom_T   Steve - My 88 Westy WBX-4 with Digifont is a deve...   Feb 2 2016, 03:52 PM
Steve Pratel   Great, thanks guys. Now I just need to find the ...   Feb 2 2016, 05:05 PM
80cap   I think the better thing to consider is that ethan...   Feb 2 2016, 05:27 PM
Ansbacher   My '74 2.0 L with dual Dellorto carbs loves 90...   Feb 2 2016, 05:48 PM
914_teener   Lets talk Octane..... What is the consensus on gr...   Feb 2 2016, 06:41 PM
Steve Pratel   Lets talk Octane..... What is the consensus on g...   Feb 2 2016, 07:24 PM
jim_hoyland   Speaking of Ethanol; manufactures of AFR gauges an...   Feb 2 2016, 06:51 PM
Mark Henry   Anything above stock CR you likely should move up ...   Feb 2 2016, 08:03 PM
carr914   E-Free! :headbanger: http://www.pure-gas.or...   Feb 2 2016, 07:25 PM
Steve Pratel   E-Free! :headbanger: http://www.pure-gas.o...   Feb 2 2016, 07:29 PM
somd914   Ethanol-free... Only a dream here in Maryland. O...   Feb 2 2016, 08:39 PM
gfg3   Ethanol-free... Only a dream here in Maryland. ...   Feb 3 2016, 04:23 PM
Mark Henry   The one thing I've wondered about is if you re...   Feb 2 2016, 09:00 PM
914_teener   The one thing I've wondered about is if you r...   Feb 3 2016, 12:11 AM
Mark Henry   The one thing I've wondered about is if you ...   Feb 3 2016, 10:25 AM
Madswede   [quote name='Mark Henry' post='2297644' date='Feb...   Feb 3 2016, 11:53 PM
914_teener   [quote name='Mark Henry' post='2297644' date='Fe...   Feb 4 2016, 09:44 AM
Dave_Darling   If you're running a stock mild, mild, mild cam...   Feb 2 2016, 10:12 PM
r_towle   I run cheap gas in everything I own. Audi, 914s, 9...   Feb 2 2016, 10:20 PM
bretth   Is it usually only the 91 octane that comes as eth...   Feb 4 2016, 08:00 AM
Philip W.   Is it usually only the 91 octane that comes as et...   Feb 4 2016, 11:17 AM
GregAmy   I'm no chemist (and I don't play one on TV...   Feb 4 2016, 10:54 AM
Mark Henry   You're far better off finding a local suppli...   Feb 4 2016, 12:02 PM
Madswede   I'm no chemist (and I don't play one on T...   Feb 4 2016, 10:08 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:22 PM
