| Henshe |
Feb 7 2016, 12:32 PM
Newbie ![]() Group: Members Posts: 15 Joined: 9-April 14 From: Burlington, Wa Member No.: 17,232 Region Association: Pacific Northwest |
Mario, of the dub shop (thedubshop.net) fabed up an awesome intake for the 914. It looks great and now I can even hear the Tangerine Racing exhaust over the itb's. (IMG:style_emoticons/default/piratenanner.gif) |
| Series9 |
Feb 9 2016, 08:06 AM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
How about: Loose the ITBs, attach the intake directly to the manifolds, and source a single throttle body from a 3.2 (or similar). Then, it's a mod with a purpose and there's no more linkage debate. (IMG:style_emoticons/default/biggrin.gif) |
| Mark Henry |
Feb 9 2016, 12:13 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
How about: Loose the ITBs, attach the intake directly to the manifolds, and source a single throttle body from a 3.2 (or similar). Then, it's a mod with a purpose and there's no more linkage debate. (IMG:style_emoticons/default/biggrin.gif) I'd actually like to see something very similar, except with a single Ford mustang 70-75mm TB. Of course that would need a 2270cc I just would like to know what the performance difference would be over ITB's. (IMG:style_emoticons/default/idea.gif) The last time I did a comparative on a similar set up (with an even larger tubing ID) the engine lost 11HP and almost 20# of torque. Air cleaner setup like posted or throttle body placement like Mark mentioned? Almost exactly like this. The approach path of the air into the carbs favors one cylinder more than the other, among other issues. Ended up going Tps for the ecu anyway so I took it off again. Going OT...what ecu are you using....I'm on SDS & could never get a good mps with the 2316 on itb's so have been on tps & it's fine. Uses closed loop for cruising, & seeks 14.1 afr nicely. That because of the ITB, not the ECU. Basically that was my question in part because of MPS signal issues and the intake noise. In my case at a ballpark 180hp, losing 10hp in a street car wouldn't be that big of a deal. This is in my bug I will be also looking at my A1 exhaust to see if I can quiet it down a bit. I guess I'm getting old. |
Henshe New intake system Feb 7 2016, 12:32 PM
McMark Throw that cross bar linkage in the trash ASAP. Feb 7 2016, 12:47 PM
02loftsmoor
... Feb 7 2016, 08:31 PM
jmill Very nice. Now you can turbo it!
:drivin... Feb 7 2016, 01:29 PM
rhodyguy How is the front of the tubing, near the filter, s... Feb 7 2016, 04:12 PM
Mark Henry Looks to me like CB Performance turbo system plumb... Feb 7 2016, 06:09 PM
r_towle Interesting, seems the cooling fan and the intake ... Feb 7 2016, 06:51 PM
Mark Henry
Interesting, seems the cooling fan and the intake... Feb 7 2016, 08:16 PM
porschetub
Interesting, seems the cooling fan and the intake... Feb 7 2016, 08:58 PM
Series9 I think we have a new entry for "Top 10 Point... Feb 7 2016, 08:19 PM
Andyrew
I think we have a new entry for "Top 10 Poin... Feb 7 2016, 10:08 PM
McMark CSP Bellcrank Feb 7 2016, 08:50 PM
02loftsmoor
CSP Bellcrank
looks better that the cross bar ... Feb 8 2016, 04:42 PM
URY914 So what is so special about it? What does it do di... Feb 7 2016, 09:57 PM
wndsrfr
So what is so special about it? What does it do d... Feb 7 2016, 10:11 PM
boxsterfan Reminds me of: http://www.osintakes.com/
:) Feb 7 2016, 10:53 PM
BeatNavy
Reminds me of: [url=http://www.osintakes.com/]htt... Feb 8 2016, 08:11 PM
Mueller Nice, I wouldn't expect any performance gains ... Feb 7 2016, 11:06 PM
Mark Henry I'd actually like to see something very simila... Feb 7 2016, 11:57 PM
Jake Raby The last time I did a comparative on a similar set... Feb 8 2016, 09:48 AM
Mueller
The last time I did a comparative on a similar se... Feb 8 2016, 10:09 AM
Jake Raby
The last time I did a comparative on a similar s... Feb 8 2016, 10:12 AM
rhodyguy Nuff said. Thanks jake. Feb 8 2016, 10:16 AM
Elliot Cannon Nice, clean installation but seems to be a solutio... Feb 8 2016, 12:21 PM
Mark Henry
Nice, clean installation but seems to be a soluti... Feb 8 2016, 02:41 PM
r_towle
Nice, clean installation but seems to be a solut... Feb 8 2016, 05:02 PM
02loftsmoor
[quote name='Mark Henry' post='2300323' date='Feb... Feb 8 2016, 05:10 PM
Harpo What about the CSP linkage? It seems like McMark ... Feb 8 2016, 04:54 PM
Elliot Cannon My linkage has been like this for over 10 years. ... Feb 8 2016, 07:57 PM
Series9 Trust me, if you take a little time to set up a CB... Feb 8 2016, 08:29 PM
McMark
Trust me, if you take a little time to set up a C... Feb 8 2016, 11:26 PM
Eric_Shea Perfect thread for "how to learn never to pos... Feb 8 2016, 10:57 PM
396 This is another interesting tread, you gotta give ... Feb 8 2016, 11:58 PM
Elliot Cannon Here's the thread I followed to improve my lin... Feb 9 2016, 01:34 AM
matthepcat Kinda seems like an intake for forced induction. Feb 9 2016, 02:21 AM
edwin Looks like one of my weekend projects from early l... Feb 9 2016, 07:24 AM
wndsrfr
Ended up going Tps for the ecu anyway so I took i... Feb 9 2016, 07:38 AM
McMark
Ended up going Tps for the ecu anyway so I took ... Feb 9 2016, 08:01 AM
edwin
Ended up going Tps for the ecu anyway so I took ... Feb 9 2016, 08:17 AM
rhodyguy The shouldered bolts Elliot mentioned eliminate th... Feb 9 2016, 07:59 AM
wndsrfr
How about:
Loose the ITBs, attach the intake dir... Feb 12 2016, 06:50 AM
Darren C Interesting centre linkage you have there Edwin.
Racer Chris
Throttle cable movement when transmitted thr... Feb 9 2016, 10:33 AM
396
Throttle cable movement when transmitted th... Feb 9 2016, 10:56 AM
Darren C
Throttle cable movement when transmitted th... Feb 9 2016, 11:00 AM
DBCooper Probably not, Chris, the coefficient of flow over ... Feb 9 2016, 10:54 AM
rgolia How about one of these? A little pricey but do the... Feb 9 2016, 11:19 AM
r_towle
How about one of these? A little pricey but do th... Feb 9 2016, 01:49 PM
Steve Pratel
How about one of these? A little pricey but do th... Feb 10 2016, 05:39 PM
rhodyguy A "little pricy"? :( dual paper filters ... Feb 9 2016, 11:24 AM
Series9 MAP sensor signal is a definite problem with ITBs.... Feb 9 2016, 01:48 PM
Series9 That's cool, but the MAP sensor problem will o... Feb 9 2016, 02:09 PM
sixnotfour
WOW, I have never seen a thread go more sideways... Feb 9 2016, 02:22 PM
Mark Henry
WOW, I have never seen a thread go more sideway... Feb 9 2016, 02:51 PM
Series9 :agree:
The "sideways component" of th... Feb 9 2016, 02:59 PM
sixnotfour I don't know either person on this post , may... Feb 9 2016, 06:16 PM
rgolia Does anyone know what unit from CSP is best for a ... Feb 10 2016, 05:47 PM
trojanhorsepower
Perfect thread for "how to learn never to po... Feb 10 2016, 05:53 PM
nathansnathan I've been working on something similar, I got ... Feb 12 2016, 05:38 PM
Racer Chris
I'm planning on using a scat linkage probabl... Feb 13 2016, 07:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:21 PM |
