| jimkelly |
Feb 9 2016, 01:31 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
last week we determined that some of my oil leak problem was 4 bolts holding my carb intake to the heads, so we applied sealant and 3 stopped leaking. on Saturday I thought i'd address the last one that did not stop leaking, so not only did I add sealant to it again, I decided to use a longer bolt because the other 3 were longer. I used a 1.5" bolt but it turns out the other were probably 1.25", the max that should be used. so anyway, monday go for a drive but power is weird, I figured it had to do with engine being cold and I just changed the fuel filter and thought maybe there was some starving going on, but 30 minutes later I decided to go back home and figure out what was wrong. anyway, yesterday I pull the valve cover off to find a cracked valve rod that I retrieved from the head with a magnet on a stick but I had to remove the intake to put the lifter back in the head. anyway, it is all back together but it revs ok in neutral but under load it is either valves or knocking. what you think? anyway, why does a guy with so little mechanical prowess own a 914, who the hell knows. i'd like to think the noise is due mostly to timing cause I of course had to pull the distributor. and I never put a tdc mark on my flywheel or crank balancer, need to, asap. I first thought it was vacuum advance problem but vacuum is pulling thru hose.
https://www.youtube.com/watch?v=tfKEa1-W0XQ video is being loaded, pls check back and comment. pls pls. Attached thumbnail(s) Attached image(s)
| Bruce Hinds |
Feb 9 2016, 03:02 PM
V-8 madness ![]() ![]() ![]() Group: Members Posts: 763 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
I've heard of push rods bending, but not breaking. Looks like your long intake manifold bolt was interfering with the push rod. You don't say the you replaced that, but I'm assuming you did . . . It's kind of hard to tell what we're listening to. It should be quiet if the lifter is properly back in it's place and the rocker arm is adjusted properly.
If the bolt was interfering with the push rod, I'd had to think where the metal filings went. It's all pretty simple stuff, but don't drive it anymore until you find out what's up. |
jimkelly help - i screwed up on my v8 - advice needed Feb 9 2016, 01:31 PM
r_towle any local mechanic should be able to help diagnose... Feb 9 2016, 01:36 PM
396
any local mechanic should be able to help diagnos... Feb 10 2016, 03:35 AM
MJHanna Man I would just replace it with something more re... Feb 9 2016, 02:14 PM
sixnotfour check compression on that cylinder ,may have a ben... Feb 9 2016, 02:33 PM
bulitt I agree with Rich find a local Chebbie guy. It doe... Feb 9 2016, 03:00 PM
screenguy914 Since at least that valve with the broken push rod... Feb 9 2016, 04:20 PM
BIGKAT_83
check compression on that cylinder ,may have a be... Feb 9 2016, 04:21 PM
jimkelly shit.. sound like the consensus is I may have a be... Feb 9 2016, 04:51 PM
Andyrew
shit.. sound like the consensus is I may have a b... Feb 9 2016, 05:34 PM
Larmo63 The problem is: You don't have a 914 engine. :... Feb 9 2016, 04:56 PM
rightpedal My bet its timing/vacuum leak. Bent valve??? I dou... Feb 9 2016, 06:16 PM
76-914 Don't feel bad Jim. I'll bet there were a ... Feb 9 2016, 06:57 PM
jmill
Wiped cam maybe.
PS if you do a compression te... Feb 9 2016, 07:13 PM
jmill Oh, if you don't know already, don't use t... Feb 9 2016, 07:16 PM
veekry9
The truth is the engine,is a write off,total re... Feb 9 2016, 07:33 PM
jimkelly don't know what's worse, bent valve or cam... Feb 9 2016, 07:35 PM
Steve Pratel If the intake manifold bolt put enough pressure on... Feb 9 2016, 07:55 PM
rick 918-S The good thing: Your working on the most common V8... Feb 9 2016, 08:08 PM
TargaToy Jim,
How did you set the lash when you installed ... Feb 9 2016, 08:14 PM
r_towle Provided everything turns with no binding once you... Feb 9 2016, 08:17 PM
Jeff Bowlsby Please remove the profanity from your title. It... Feb 9 2016, 08:32 PM
Steve Pratel
Please remove the profanity from your title. It... Feb 9 2016, 09:28 PM
whitetwinturbo Time to upgrade?
Feb 9 2016, 09:52 PM
dwillouby Lots of good advice here. Get new pushrod and inst... Feb 10 2016, 07:49 AM
jimkelly compression test of cylinder in question #4. the ... Feb 10 2016, 10:10 AM
Justinp71
compression test of cylinder in question #4. the... Feb 10 2016, 02:04 PM
Steve Pratel
compression test of cylinder in question #4. the... Feb 10 2016, 02:44 PM
Justinp71
You need to compare that reading with other cyls... Feb 10 2016, 03:03 PM
JOEPROPER It's an old Chevy... Put a push rod in, adjust... Feb 10 2016, 10:35 AM
ThePaintedMan I know you're learning... but just FYI.. that... Feb 10 2016, 03:38 PM
veekry9
It's an old Chevy... Put a push rod in, adjus... Feb 10 2016, 03:43 PM
bretth As others have said, disable ignition and fuel pum... Feb 10 2016, 04:39 PM
Bruce Hinds I don't know why you all keep talking about a ... Feb 10 2016, 05:49 PM
jimkelly thanks guys for all the great advice. I am taking... Feb 10 2016, 06:23 PM
whitetwinturbo Drag a big time magnet through the old oil to find... Feb 10 2016, 07:59 PM
Cairo94507 Good tip. Best wishes. Feb 10 2016, 11:08 PM
veekry9 If it all goes bad,here is a cheep way out:
https:... Feb 11 2016, 03:29 AM
jimkelly those are good deals but I need a pre 1986 engine ... Feb 11 2016, 11:27 AM
Scott S I did this exact same thing 25 years ago (too long... Feb 11 2016, 01:56 PM
69telecaster I have a fresh '76 400 with increased compress... Feb 11 2016, 02:26 PM
jimkelly what i'd really like is a low power/high rev s... Feb 11 2016, 03:07 PM
Andyrew
what i'd really like is a low power/high rev ... Feb 12 2016, 10:51 AM
veekry9 OsGqmOQus6Y
How to.
(WYIT)
A dab of axle grease... Feb 12 2016, 10:32 AM
whitetwinturbo 283 Chevy will rev :beer1: Feb 12 2016, 11:33 AM
zipedadoo What about a 4.3 V6? Everything bolts up just like... Feb 12 2016, 11:54 AM
mgp4591
What about a 4.3 V6? Everything bolts up just lik... Feb 12 2016, 01:14 PM
jimkelly I really like the idea of a v6 for the extra space... Feb 12 2016, 05:27 PM
Justinp71 I used to have a built 350, revved to 6500 all the... Feb 12 2016, 02:40 PM
jimkelly when people say a sbc can be reved to 6500 or some... Feb 12 2016, 05:28 PM
mgp4591
when people say a sbc can be reved to 6500 or som... Feb 12 2016, 05:54 PM
Justinp71
when people say a sbc can be reved to 6500 or som... Feb 12 2016, 11:22 PM
veekry9 gGT_qP14Hig
https://www.youtube.com/watch?v=RkJ3fd... Feb 12 2016, 06:26 PM
mr914 Got just the motor to replace yours.
May require ... Feb 13 2016, 04:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 03:45 AM |
