> help - i screwed up on my v8 - advice needed
jimkelly
post Feb 9 2016, 01:31 PM
Delaware USA
last week we determined that some of my oil leak problem was 4 bolts holding my carb intake to the heads, so we applied sealant and 3 stopped leaking. on Saturday I thought i'd address the last one that did not stop leaking, so not only did I add sealant to it again, I decided to use a longer bolt because the other 3 were longer. I used a 1.5" bolt but it turns out the other were probably 1.25", the max that should be used. so anyway, monday go for a drive but power is weird, I figured it had to do with engine being cold and I just changed the fuel filter and thought maybe there was some starving going on, but 30 minutes later I decided to go back home and figure out what was wrong. anyway, yesterday I pull the valve cover off to find a cracked valve rod that I retrieved from the head with a magnet on a stick but I had to remove the intake to put the lifter back in the head. anyway, it is all back together but it revs ok in neutral but under load it is either valves or knocking. what you think? anyway, why does a guy with so little mechanical prowess own a 914, who the hell knows. i'd like to think the noise is due mostly to timing cause I of course had to pull the distributor. and I never put a tdc mark on my flywheel or crank balancer, need to, asap. I first thought it was vacuum advance problem but vacuum is pulling thru hose.
https://www.youtube.com/watch?v=tfKEa1-W0XQ
video is being loaded, pls check back and comment. pls pls.
JeffBowlsby
post Feb 9 2016, 08:32 PM
Please remove the profanity from your title. It's offensive.
Bulldog9
post Feb 9 2016, 09:28 PM
QUOTE(Jeff Bowlsby @ Feb 9 2016, 10:32 PM) *
lol funny guy......
jimkelly   help - i screwed up on my v8 - advice needed   Feb 9 2016, 01:31 PM
r_towle   any local mechanic should be able to help diagnose...   Feb 9 2016, 01:36 PM
396   any local mechanic should be able to help diagnos...   Feb 10 2016, 03:35 AM
MJHanna   Man I would just replace it with something more re...   Feb 9 2016, 02:14 PM
sixnotfour   check compression on that cylinder ,may have a ben...   Feb 9 2016, 02:33 PM
bulitt   I agree with Rich find a local Chebbie guy. It doe...   Feb 9 2016, 03:00 PM
Bruce Hinds   I've heard of push rods bending, but not break...   Feb 9 2016, 03:02 PM
screenguy914   Since at least that valve with the broken push rod...   Feb 9 2016, 04:20 PM
BIGKAT_83   check compression on that cylinder ,may have a be...   Feb 9 2016, 04:21 PM
jimkelly   shit.. sound like the consensus is I may have a be...   Feb 9 2016, 04:51 PM
Andyrew   shit.. sound like the consensus is I may have a b...   Feb 9 2016, 05:34 PM
Larmo63   The problem is: You don't have a 914 engine. :...   Feb 9 2016, 04:56 PM
rightpedal   My bet its timing/vacuum leak. Bent valve??? I dou...   Feb 9 2016, 06:16 PM
76-914   Don't feel bad Jim. I'll bet there were a ...   Feb 9 2016, 06:57 PM
jmill   Wiped cam maybe. PS if you do a compression te...   Feb 9 2016, 07:13 PM
jmill   Oh, if you don't know already, don't use t...   Feb 9 2016, 07:16 PM
veekry9   The truth is the engine,is a write off,total re...   Feb 9 2016, 07:33 PM
jimkelly   don't know what's worse, bent valve or cam...   Feb 9 2016, 07:35 PM
Steve Pratel   If the intake manifold bolt put enough pressure on...   Feb 9 2016, 07:55 PM
rick 918-S   The good thing: Your working on the most common V8...   Feb 9 2016, 08:08 PM
TargaToy   Jim, How did you set the lash when you installed ...   Feb 9 2016, 08:14 PM
r_towle   Provided everything turns with no binding once you...   Feb 9 2016, 08:17 PM
Jeff Bowlsby   Please remove the profanity from your title. It...   Feb 9 2016, 08:32 PM
Steve Pratel   Please remove the profanity from your title. It...   Feb 9 2016, 09:28 PM
whitetwinturbo   Time to upgrade?   Feb 9 2016, 09:52 PM
dwillouby   Lots of good advice here. Get new pushrod and inst...   Feb 10 2016, 07:49 AM
jimkelly   compression test of cylinder in question #4. the ...   Feb 10 2016, 10:10 AM
Justinp71   compression test of cylinder in question #4. the...   Feb 10 2016, 02:04 PM
Steve Pratel   compression test of cylinder in question #4. the...   Feb 10 2016, 02:44 PM
Justinp71   You need to compare that reading with other cyls...   Feb 10 2016, 03:03 PM
JOEPROPER   It's an old Chevy... Put a push rod in, adjust...   Feb 10 2016, 10:35 AM
ThePaintedMan   I know you're learning... but just FYI.. that...   Feb 10 2016, 03:38 PM
veekry9   It's an old Chevy... Put a push rod in, adjus...   Feb 10 2016, 03:43 PM
bretth   As others have said, disable ignition and fuel pum...   Feb 10 2016, 04:39 PM
Bruce Hinds   I don't know why you all keep talking about a ...   Feb 10 2016, 05:49 PM
jimkelly   thanks guys for all the great advice. I am taking...   Feb 10 2016, 06:23 PM
whitetwinturbo   Drag a big time magnet through the old oil to find...   Feb 10 2016, 07:59 PM
Cairo94507   Good tip. Best wishes.   Feb 10 2016, 11:08 PM
veekry9   If it all goes bad,here is a cheep way out: https:...   Feb 11 2016, 03:29 AM
jimkelly   those are good deals but I need a pre 1986 engine ...   Feb 11 2016, 11:27 AM
Scott S   I did this exact same thing 25 years ago (too long...   Feb 11 2016, 01:56 PM
69telecaster   I have a fresh '76 400 with increased compress...   Feb 11 2016, 02:26 PM
jimkelly   what i'd really like is a low power/high rev s...   Feb 11 2016, 03:07 PM
Andyrew   what i'd really like is a low power/high rev ...   Feb 12 2016, 10:51 AM
veekry9   OsGqmOQus6Y How to. (WYIT) A dab of axle grease...   Feb 12 2016, 10:32 AM
whitetwinturbo   283 Chevy will rev :beer1:   Feb 12 2016, 11:33 AM
zipedadoo   What about a 4.3 V6? Everything bolts up just like...   Feb 12 2016, 11:54 AM
mgp4591   What about a 4.3 V6? Everything bolts up just lik...   Feb 12 2016, 01:14 PM
jimkelly   I really like the idea of a v6 for the extra space...   Feb 12 2016, 05:27 PM
Justinp71   I used to have a built 350, revved to 6500 all the...   Feb 12 2016, 02:40 PM
jimkelly   when people say a sbc can be reved to 6500 or some...   Feb 12 2016, 05:28 PM
mgp4591   when people say a sbc can be reved to 6500 or som...   Feb 12 2016, 05:54 PM
Justinp71   when people say a sbc can be reved to 6500 or som...   Feb 12 2016, 11:22 PM
veekry9   gGT_qP14Hig https://www.youtube.com/watch?v=RkJ3fd...   Feb 12 2016, 06:26 PM
mr914   Got just the motor to replace yours. May require ...   Feb 13 2016, 04:25 AM
- Lo-Fi Version Time is now: 12th August 2026 - 03:45 AM
