EBay Six 22 bids at $85,100 with days to go. . |
toolguy |
Feb 8 2016, 09:09 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Looks like an L.A. car,
where will this one end up. . Now at $85 large with 6 days to go http://www.ebay.com/itm/191799462499?_trks...K%3AMEBIDX%3AIT |
gcrotvik |
Feb 10 2016, 08:25 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I guess anyone can call a car concours quality. Here are some of the few inaccuracies in this restore:
Front hood release sheath was painted body color with the car Front strut top hardware painted body color with the car Charcoal filter is missing in front trunk at fuel tank Rubber mounting buffer is missing for right eyebrow Wrong style screws holding down the front lower trunk latch (should be hex cap) No securing clip to hold the front trunk pull cable sheath to the front lower latch Front sway bar not connected to A arms (I believe all 6's came with front sway bars) Charcoal breather lines in engine compartment are missing Wire harness tie down plastic covers, right side against the firewall painted body color Wire harness in engine compartment, left side against the firewall is painted body color Rubber buffers for engine cover/lid are not correct (6 sided, not round) Positive battery cable end is not correct Negative battery cable is installed upside down No engine compartment relay board cover Late 914 filter screen in interior breather tube/hole in left door jamb (but not in right side, which is correct) Interior light looks to have a black switch, which is not correct Center cushion is aftermarket Colgan Late style hand brake lever Front side marker seals are aftermarket and not even close to the correct profile Bumpers have not been re-chromed Rear bumper has a slight dent in it to the right of the license plate Front and rear deck lids do not fit all that well (may be due to new seals) Mounting nuts missing on the C in P O R S C H E on the rear engine lid No plastic/nylon trim caps in rear trunk floor Incorrect mounting nuts on the 914-6 tail panel emblem Incomplete tool kit with incorrect tools The question I would ask, what else is incorrect that you don't see? |
Lo-Fi Version | Time is now: 1st June 2024 - 07:03 AM |
