| ripper911 |
Feb 10 2016, 08:05 PM
corde pulsum tangite ![]() ![]() ![]() ![]() Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
I am here to draw upon the wealth of mechanical knowledge on this forum to help diagnose my brothers chevelle. I don't know much about that type of engine.
I believe the engine is a 400ci that has been destroked to 377ci. It recently started flattening the spark plug gaps. He doesn't think the rods have stretched because they are supposedly high quality. It doesn't sound like the crankshaft is moving around or anything. He's a mechanic, neither he, his boss, nor anybody else he's asked has been able to figure it out. |
| Bulldog9 |
Feb 10 2016, 10:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 706 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Plugs are likely too long.
Even if they are the stock plug, a modified setup may require a shorter plug. Things may have been fine for a while but carbon buildup on the piston may raise the height just enough to now make contact. I would measure the threaded portion of the head, then the threaded area of the plug. If the plugs have been in for a while and the plug is too long, even long enough to protrude in the combustion chamber the lower threads will be discolored. That is an easy check. One other thing to think about, the plugs for most SBC engines DIDDNT come with a crush ring or jacket. Back in the day we would add a copper crush ring to the plug when we were worried about this. I'm sure they are still available. I'd add a gasket then run some serious cleaner at high concentration, then change oil and see how things go. |
ripper911 NPC! Engine problem Feb 10 2016, 08:05 PM
messix carbon on the pistons contacting the plug ? Feb 10 2016, 08:22 PM
r_towle He may be using the wrong plug or he may have forg... Feb 10 2016, 08:26 PM
walterolin Wrong plug? Feb 10 2016, 08:26 PM
ripper911 I'll mention those things. It started doing i... Feb 10 2016, 08:30 PM
Bruce Hinds There long and short reach plugs.
Did he change p... Feb 10 2016, 08:32 PM
rick 918-S Who built the engine? Are the heads shaved? I agre... Feb 10 2016, 08:41 PM
ripper911 He says that he's running the same plugs that ... Feb 10 2016, 08:49 PM
zipedadoo Is the transmission an automatic?
On some of the... Feb 10 2016, 09:24 PM
ripper911 I believe he changed from a 3 speed to a 4 speed, ... Feb 10 2016, 09:38 PM
zipedadoo I don't think any of the 4 speeds used a vacuu... Feb 10 2016, 09:49 PM
Tom_T I think the above are all good suggestions to look... Feb 11 2016, 12:49 AM
jmill
a great powertrain, but for the life of me I can... Feb 11 2016, 07:03 PM
Bruce Hinds
a great powertrain, but for the life of me I can... Feb 11 2016, 07:31 PM
cwpeden Wrist pins? Feb 11 2016, 07:38 PM
veekry9 Go ahead,snoop around.
All will be revealed.
http:... Feb 12 2016, 08:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:27 PM |
